sudo apt-get purge 930
Throttle bypass screw question
Does the throttle bypass screw (for adjusting idle) have any relation to AFR? At the correct AFR my bypass screw needs to be all the way in to maintain proper idle, I can't go any further. Is there a relationship between AFR and idle screw such that if I back out the screw and adjust the mixture screw at the same ratio will I get the same mixture?
BTW, if you ever have your AFR's swinging all over the dial along with super mega hella rich at the onset of boost causing the car to bog check power to the WUR. Ask me how I learned that one!
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I don't think it does beyond once the AF is dialed in, you set the rpms.
I could be wrong though... |
It is idle speed adjustment only.
Some multi throat Weber and Dellorto carbs also have individual throttle butterfly air bypass screws for synchronising the individual carberator throats only, and some of them whistle a little with each intake stroke at idle. Those carbs also have air correction adjustment screws for idle mixture adjustment of each carb throat, but there is no such thing as an air "correction" CO adjustment on CIS. |
I wonder why I need to have that screw dialed all the way in to set the idle properly???? I've checked several times for vacuum leaks and can't find anything. I replaced all of the gaskets and seals recently.
It's pretty difficult to tell if any injector blocks are cracked or one of the 12 gaskets surrounding them are leaking without removing them.
There are alot of places that could be a vacuum leak. |
I'm with Jim. Sounds like a vacuum leak. Try spraying flamable brake/carb cleaner at all joints and listen for an rpm increase.
Crotchety Old Bastard
The idle adjustment scew is no more than a controlled vacuum leak (around the trottle), if it is all the way shut and still idles too high then there is a leak somewhere else. Do you have the stock BOV? A 930's best place to hide a vacuum leak.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Found it. The AAR was not operating and was staying open. I blocked it off and had to readjust.
Smart quod bastardus
Exactly the same issue I had, The AAR was not closing all the way and in order to get a 950 rpm idle the air adjustment screw was all the way in. I removed the AAR valve body and plugged the hoses that went to it and now run without the damn thing. It only requires a little effort withe the gas pedal upon starting the car in colder weather, but thats fine.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
I thought about installing a 12vdc 30psi NC solenoid valve wired to a switch up front for cold starting. That way I could have the bypass work when I wanted it to without any issues. Sort of a manual electric bypass valve.
I eleminated my AAR and AAV when I moved to AL. The idle is low (700rpm) for a couple minutes but no big deal. I have a manual throttle assembly from an earlier 911 that I wanted to install for this function but like everything else my car comes last so it hasn't been installed.
I've also replaced the BOV gaskets.
Try it for awhile without it and see what happens.
You could also install a BMW 320i heater valve in place of the cold start AAR, the 2 hose connections are the same size, and run a generic pull/push carburator choke cable to somewhere around the auto heat box between the seats and use it as a nice mechanical/adjustable cold start high idle device that wouldn't interfere with the throttle linkage.
They're kind of expensive new now.. part #64-11-1-366-669-BOE Pelican Parts - Product Information: 64-11-1-366-669-BOE ...but there's lots of them in salvage yards for real cheap. I think the 944 heater valve is the same and would also work and cost way less... 944-572-085-02-M53 The body is plastic and it has a connection and clamp for a cable, and 2 hose connections that are the same size as the CIS AAR valve.
Tinkering Pays!!
I've removed all of the AAR's and AAV's a long time ago, etc... All hoses are new along with intake blocks. The car starts and idles on it's own when cold. The idle starts out at about 500 RPM when cold [maybe this is normal with all accessories removed], but slowly goes to 1,200 over the next 10-minutes of warming up. my idle screw is all the way in... i'd really like to have the car idle at 900 when warm, so I need to find the leak!!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. Last edited by mooney265; 03-08-2010 at 04:57 PM.. |
Another place that can be a vacuum leak is the brake booster fitting and hose that is rubber hose with hoseclamp on to a metal tube through the center tunnel and then another rubber hose and clamp down in between the transmission mount and floor pan.
Then the hose eventually attatches to the intake manifold on the left side. |
Tinkering Pays!!
*** could I just disconnect and plug at the intake manifold while idling and see if idle drops??
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
Shannon, here are a few of my favorite hidden sources of vac leaks:
> AAR that does not close all the way > Throttle Bypass valve with a blown diaphagm > AAV stuck in the open possition > Injector blocks with spiderweb cracks > Loose injector blocks > Any vac hose that leaves the engine compartment (brakes, boost gage, etc) Loose injector blocks are commonly overlooked.
