proffighter's Avatar
Thanks guys
My drill is ready for action
I am on vacantion from 11th until 20th of September, so you have to be patient for updates here... Maybe if I got a little time before, let's see
Roland
930 Turbo '81 Too many modifications to list
Old 09-08-2014, 01:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #461 (permalink)
Finally some news
After my vacation I did not made much, at least not to show, so here the first worth to. To save some more weight, I worked on the doors / window frames:
Drilled, shorten and tappered all bolts:
Lighter version of the glass base, this time all aluminum and Tubtaras:
Window frame assembled, little triangle drilled as well:
Installed with belt (Aluminum nut and bolt hollow drilled ) Aluminum bolt as lower stop:
Roland
Old 10-29-2014, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #462 (permalink)
Max Sluiter
Flieger's Avatar
I love it.
Old 10-29-2014, 05:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #463 (permalink)
Even a little save is a save... I replaced the steel bolts of the front flasher housing by aluminum bolts. Just drilled out the old ones until the head break, removed the threaded rest and the new ones fitted perfect:
Roland
Old 10-30-2014, 10:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #464 (permalink)
70's BMW 2002's and the E21 chassis 320i that followed it used plastic thumbscrew nuts on the tail light lense studs that should fit your aluminum bolts. They may be a hair lighter than steel nuts and don't corrode.
Old 10-30-2014, 11:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #465 (permalink)
I gotta say Roland, your build is amazing. The sheer amount of fabrication work and the level of detail is astonishing.
I'm sure this has been asked but if so I don't recall. Do you have a target weight your shooting for ? If not any idea on the finished weight ?
Keep up the fine work.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 10-30-2014, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #466 (permalink)
I will use aluminum nuts here as everytime where not that much strength is needed. But plastic nuts are good as well, will check this as well
Roland
Old 10-30-2014, 02:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #467 (permalink)
Thank you for the nice words!
Yes this has been asked before but no problem, long time ago since and goals can change... But as there was none there is still none. I just want to follow my principles and see what I get at the end.
I guess it will be below 1000kg.
Roland
Old 10-30-2014, 02:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #468 (permalink)
Finally I found time to finish the weight reduction on the seat rails. As they are that beefy, especially compared to the FIA aluminum lateral seat brackets, I had no fear to remove some material here. They still are quite massive:
Roland
Old 11-07-2014, 06:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #469 (permalink)
Long time ago,but still nothing worth to show... be patient fellows
However, does anyone bought or had contact with Patrick Motorsports?
Want to buy an oil cooler from them and asked something using the form on their website, no answer since almost two months now. So I wrote again, but this time an email, no answer either since a couple of weeks... I do not expect immediately answer from small companies and one man shows, but this?
Other here, Brian is quick as hell and is alone too...
Roland
Old 01-08-2015, 06:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #470 (permalink)
lite75's Avatar
Talked to them about a month ago, good guys just busy.
75 930, 76 930, 83 SC EFI turbo
Old 01-08-2015, 08:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #471 (permalink)
speednme1's Avatar
Best is to call them. James is a good dude. I've visited their shop and have purchased from them.
Rey....77 930 "the Mistress"
Old 01-08-2015, 11:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #472 (permalink)
911-2,8-RSracer's Avatar
Hi Roland,
any news?
Old 01-23-2015, 02:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #473 (permalink)
Yes indeed, but not big ones. Made some spacers for the rear swaybar for two reasons:
- My engine is 10mm lower than stock, so tranny was really close to the bar.
- After I made my tranny beam Mark II out of aluminum, it was slightly wider than Mark I steelmade,
so I have to move the bar for that reason too.
And that's the way the spacers look:
Present beam, not anodized yet. I am not sure if I should leave it colorless or go black (tend to black for now):
Roland
Old 01-24-2015, 03:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #474 (permalink)
jsveb's Avatar
I'd go black.
Still a pleasure to watch your progress.
Old 01-24-2015, 08:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #475 (permalink)
While I still struggle with the finish of my tranny beam, I spent some time on the starter and anodized the raw aluminum flange to avoid contact corrosion. Further the grey stator housing looked so old I painted in black too:
Short said, only some different color
Roland
Old 02-03-2015, 01:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #476 (permalink)
Kartoffelkopf
Spenny_b's Avatar
Hi Roland, nice work as always....what brand starter is that? Looks trick
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 02-03-2015, 03:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #477 (permalink)
Kozmo930's Avatar
been awhile
Hi Roland had to check in ,been awhile ...busy with life in general
But as usual your car just amazes me had to go back through some pages to catch up , but "WAY BACK" seen your front coil overs mounted. Wondering how much room you have between your brake line and tie rod arm ? could a 3" hoes fit ??? I almost have the mock up done in fiberglass for the brake ducs . With my raised spindles I'm running my intake hose under the tie rod arm , but hoping I can find someone here to trial fit some on stock spindle height struts . Made some good mods to them to tuck them in real close and wrap around tube very nicely (not to long not to short) final products will be in carbon
Keep it in mind , I see you still have some time before you hit the road . I need the swiss watch approval
Kozmo
Old 02-07-2015, 08:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #478 (permalink)
Thumbs up
Hi Roland,
Looks great as always! I like following your thread and check in for updates. I admire your dedication to reducing weigth, it will be exiting when you put it on the scales once finished.
Just a suggestion about the starter bracket, remember that the starter grounds through the bracket and the anodizing isolates the starter from the gearbox. So you need to ground the starter in some other way or remove some of the anodizing to create contact. Saves a lot of tears when trying to find out why the starter does not work .
Old 02-08-2015, 03:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #479 (permalink)
Kozmo
Kozmo
May you post a pic what measurement exactly you want, so I will check for you
Roland
Old 02-11-2015, 04:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #480 (permalink)
