The most common reply from USA manufacturers that I hear is “supply chain issues”
You would probably be fine if you wanted Small Block Chevy Main Studs. A friend of mine ordered ARP wheel studs for the rear axle of his ‘68 Dodge Charger in August last year and they just showed up this week. |
Yes, 100% made in America. Honestly, I'm just glad they are still making these parts for such a small, niche market.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Well, it may be true for trough bolts (even if I doubt you'll get them in time), but for the case bolt kit it's allover the shops and even ARP themself the fact that they move the date almost daily a couple of days forward and this happen since over half a year. If you can send me the item within 4 weeks I'll pay you another 100USD on top, but if you can't you give me a discount of 100USD
Roland 930 Turbo '81 Too many modifications to list |
Play at the cups is normal, I lapped the end of each cup flat on my surface plate to remove any marks from previous wear.
Today I started with workin on the piston pins, machined conical by 14° axial on the lathe to save some weight on the oscillating mass. Made this on the old pins as well without any issue. The weakest area is the piston there, not the pin.
BTW What size of pics do you choose to upload here? With about 4Mb it's incredible slow...
So nice to have access to a lathe.
If I remember I crop pictures down to a couple meg. I am usually uploading from my phone and it's very slow. Almost as annoying as having few people respond to my posts. David |
yes, a lathe is a must when your doing much DIY in my eyes...
Road & Race Inc.
Does anyone has expierence with them, page msroadrace in LA. Sent them a message with questions for a used 965 IC I found on there page and they sent me without any reply a Paypal request for about 15'000USD they have on ebay...??? Normal behavour or WTF?
Max Sluiter
I've heard of them but not in a good way, however nothing concrete. Just odd stuff like that and high prices. I'd steer clear.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Thank you. What I've found out as well.
Super impressive work!
Still waiting for ARP able to deliver... but in between I can do other things like:
I bought a 964 IC to replace my Blownsix IC (too big for my needs) and the intake air temp sensor from my SDS EFI does not fit. Id did not on the Blownsix where I fitted a threaded insert, but here I wanted to leave the IC as it is. So I made a sensor housing to "transplant" the sensor.
Great solution, well executed!
Some additional info about the sensor above. Cylinder part is 0.1mm thicker than bore in the flange. Mounted with heath shrinking (Cold cylinder, hot flange). Anodized after. Sensor is also press fitted, but to be save as it's something like PA6GF I filled the groove with uv-activated glue. First time I used it, very cool stuff.
Another thing I am working is the fan housing cone (or what it's called). I guess it's not unusual that it have cracks or break completely. Cut away generous Filled gap with fiber reinforced epoxy and drilled the hole circle
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 03-14-2023 at 02:39 PM.. |
hmm pics lost...
Fear No Rust
You are doing really nice work! Your engine will be amazing when done.
I like the anodized pieces you did. I have done a lot of zinc plating but not tried anodizing yet. John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937 Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106 |
...Then it's time to start
Proceeded on the fan housing cone. Finish and painting done
I made copies of the air guides out of fiberglas composite Weight saving of 126gr is quite nice ![]() and finally ready to mount
