LinkBack Thread Tools Rating: Thread Rating: 11 votes, 4.55 average.
LWB LWB is offline
Originally Posted by proffighter View Post
Hi Garry
All fine, thanks for asking. Spent a lot of time doing other things, for example bought a new lathe and drillpress (or whatever you call that in english). Took quite a lot of time to install them in a smart way in my little room. Also search for the most usefull options/tools is timeconsuming. However I am done more or less now and will go on with working on the car. But no hurry, it's summertime here
Hello from Canada. I've been following your thread for a couple of years. Outstanding work! Hope to hear from you soon
What lathe did you end up buying?
Old 01-08-2020, 08:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #601 (permalink)
Me too
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 01-13-2020, 09:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #602 (permalink)
proffighter's Avatar
Did you know...
... I am still here
Time is running and progress is very little (not only because of Corona).
Have some issues with Cork damping mats, glue came off, PITA when quality causes issues. However made some floor boards, will post pics later
Until then, hope you guys are fine as well
Roland
930 Turbo '81 Too many modifications to list
Old 07-09-2020, 04:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #603 (permalink)
All caught up on your posts! Ready for more updates :] Keep up the excellent work!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 07-09-2020, 07:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #604 (permalink)
TurboKraft's Avatar
Roland, great to see you here again. We miss your amazing posts! Be well, friend!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 07-09-2020, 12:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #605 (permalink)
Thanks guys. You deserve a little teaser then
Roland
Old 07-09-2020, 01:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #606 (permalink)
now with pic
Made floorboards out of Balsa plywood 11mm and self-adhesive thin carpet (only 1.5mm), not easy to make as nothing is rectangular or straight. Also under the seat it's changing height, therefore i made 3 pieces. More details and pics next week.
Roland
Old 07-09-2020, 01:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #607 (permalink)
Very cool.
I don’t know how you could have a car under the knife for so long without driving it.
I guess you know it’s safe and being built properly and time - does - fly.
Looking forward to seeing more updates.
Hello from Cleveland OH USA
Old 07-10-2020, 11:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #608 (permalink)
While still working inside on interieur etc. I also continued on the wiring harness. There I found a brittle grommet, in fact two of them. They are for the rear lights for the break-through of the cable at side wall (biggest hole there, about 27mm) but they are replacing the OEM connector there, but could be Porsche from somewhere else. Maybe one of you recognize it. I searched a bit on the net, but did not found exactly the same or at least equal useful. I like the fact it can be bent as it's needed there.
Here are the measurements:
Roland
Old 06-29-2022, 05:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #609 (permalink)
very angry
I just wrote a huge text and added some pics and when I clicked on submit reply I was logged out! WTF? Further the forum is not able to handle normal sized pics (others can reduce size while uploading. It's a pain in the ass to reduce all the sizes before uploading. I know we are all thankful for this forum, but it's not that user friendly I was used to. Why it logs me out while writing?
Roland
Old 07-07-2022, 01:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #610 (permalink)
As i am not willing to spend another half hour to write again (at least for the moment) here the short version:
I cannot find the aluminum clad glass fiber mat I used 20 years ago, to stubborn to fit without wrinkles, not possible to drape nicely, I decided to go on with the wiring until I find someting useful (open to suggestions).
have to fit connectors for standard functions and EFI as well. Therefore splited in two connections
Roland
Old 07-07-2022, 01:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #611 (permalink)
Unfortunately I need to make a new board for the coils to mount the connectors nicely. Here is what i decided to do. I checked other positions like beside the fuel filter/strut, but for better access in case of issue I think the stock position is best:
Top view with plug in position
The receptable lookes like this Deutsch DTV 18 BTW:
Roland
Old 07-07-2022, 01:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #612 (permalink)
Because i have now much more room for relay and fuses, I want to fit a nicer box for those, more like in the front than each mounted one by one. A first search was not successfull, 2-4 fuses and 1 relay within one box and transparent cover would be nice. Maybe I have to work on one getting close to fulfill my goal
Regarding the connectors, I guess there is no problem with pipe from turbo to IC when I check my old pics of this area.
Roland
Old 07-07-2022, 01:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #613 (permalink)
DIY wrencher
Long time no post Roland, good to see you back!
Have you considered using a modern PDM? Much less wiring, lighter, and more functional in many ways, could be ideal for a hotrod like yours that is more about performance than originality.
LG aus Wien,
Lukas
PS: If you write a long post it could be worth using a word processor like MS Word installed locally on your computer to draft it, so that you can be sure it will not get lost.
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 07-11-2022, 12:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #614 (permalink)
Servus Lukas
Yes. But I was never away, just nothing worth to post or nothing done at all... I try to make some more progress but it won't be like 10years ago, too much other things to do or like to do
However back on the things here:
Yes I checked something like PDM. Forgot the brand, was a decade ago I guess. There was something like a Master box in the front (or where you like) and one little at the dashboard for instuments and one in the back of the car. connected by data bus. At the end my decision was against. Can't remember in detail but mainly it was:
-not sure on request at the seller, that all signals can be "transferred" for sure, for example analog flashing by relay
-due the position of the components, sensors, etc. rear engine, front fuse box etc. still a lot of wiring needed.
-probably not that much if any weight saving.
-My car is pretty "empty" anyway, without that wiring it would look even more "incomplete"
-Heat/Water resistance of the box (in the engine compartment) not guaranteed.
-Very expensive (at teast then, no idea today)
-not a stand alone thing, PC or so needed for diagnosis, programming etc. Doubt it can be repaired/checked on the road without equipment.
Yes, the transfer via word and not writing directly was what I did in the earlier days, just forgot about.
Roland
Roland
Old 07-11-2022, 04:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #615 (permalink)
To get the connectors a bit closer together, I machined the mounting areas so I can use one single bolt for both housings. Saved about 30mm (and of course important to me some weight as well)
Roland
Old 07-11-2022, 04:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #616 (permalink)
Banned
Hey Roland - great to see you back here and still continuing with your project. Nothing to offer but hello and keep up the progress there 8 )
Old 07-11-2022, 06:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #617 (permalink)
Turbofrog
smurfbus's Avatar
I chose to go with front and rear Ecumaster PMU16. No more relays or fuses (minus power windows).
Do you have a pic of your wiper assembly and how has it worked? IIRC you drilled the **** out of the rods or did you find a light weight motor for it?
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 07-11-2022, 11:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #618 (permalink)
You find some pics on page 5 here. If you need futher view/details, let me know. Forgot to weight back then so I can't tell the savings. No other motor for now, but who knows
Roland
Old 07-12-2022, 11:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #619 (permalink)
Today I found a little time to go on with the coil board. But first I had to make some custom blade (or how it's named) for my hand bending tool. Otherwise I could not bend only part of the board but only full length. Now i can leave about 20cm flat while bending the rest. I mounted on the other side (silver part) so I can still use the whole wide if needed, easy to flip.
After a few bents and cutting first test fit. Nice, just like I wanted:
Roland
Old 07-12-2022, 11:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #620 (permalink)
