Slantnose from HELL
It changes from time to time..... |
Mr. C
" Mr.C " Six = Sex Last edited by SAY - 642; 05-24-2014 at 09:45 AM.. |
Registered Abuser
hot damn, where's that pic from? if it's someone you know, much respect to your skills (women and photography).
Want the hot chicks you need to dump your 930 and get an old longhood like this one.
Looks like an old shot of a hippie chic. |
there's a crack in the dashboard
Brando
On the dashboard
Bwahaha "Crack on the dashboard "
Slantnose from HELL
in, on and by
Preferred pronoun:Maestro
Someone must have a tube of crack-filler.
When in doubt, use overwhelming force. |
FYI They changed the rubber centered clutch in the seventies, due to their ongoing quest for the perfect car (you should know this) Im up to 250000 km on my Daily Driver Stock all Porsche factory Engine 911 Turbo 930, So what are you talking about? Amount of times ive broken down from failed sock part = ZERO repeat ZERO Yes i think it is the perfcet car as it is, a Factory 930 especially a Euro version is ultimate, Whats so good about a giant flippin intercooer that its main use is for people to hide their dirty motors as it covers everything which is such a shame. PLease do cut one away lets see what technological marvels lies underneath, i think people dont want to know because they dont want to see that there is in fact nothing there? People think that i big shiny block of steel will give them more power, shame though because of the weight it adds any alleged power gain is unnoticable Hey give me 2 grand and ill upset the rear weight bias even more,!! talk about unbalanced (in more ways than one) sheesh And even with the fuse box half rewired amount of times Ive broken down = ZERO I had a clutch problem i thought once but that turned out to be the floor carpet had curled up under it, i fixed my clutch problem by moving it back three inches. Amount of times ive broken down by adding an aftermarket part = 1 (fancy that) That aftermarket part is now deleted im sticking to Porsche parts only So what are you Talking about? You Sound like a Salesman for an aftermarket parts shop I couldnt resist after your comments about my fusebox, (i know your jealous) But let the truth be known! Without prejudice Rob
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver Last edited by Robbbyg; 05-25-2014 at 02:52 AM.. Reason: / |
Big Deal and two months later i bet the motor blew cos it made it unbalanced and unreliable Show one thats been there for 200000 plus kays ONLY then you can say its as good as or better than factory !
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
Oh and on aftermarket vs stock...it mainly depends on what you are doing with your car. If you are going to add an aftermarket part, make sure you source a reputable mfg. They're plenty of crappy China mfg aftermarket parts being sold. On the flip side many aftermarket parts have been carefully designed and tested by reputable shops. Are they cheap? NO...but if you are going to go aftermarket then you're going to have to crack open that wallet. Stock parts are just that...STOCK....for when no modification is wanted or needed.
Rey....77 930 "the Mistress" |
What ever happened to BlownSix? They use to make a very nice full bay intercooler with billet end tanks at a very reasonable price. It looked pretty choice to me. I think last time I saw them posted on Ebay for like $1500. I was about to buy one but dragged on it and then when I went looking again, they were gone. At the time, it was the best full bay intercooler out there for the money. Most of the full bay intercoolers available now are: "take out a second mortgage" items.
Hey, SAT-642 that is awesome response! Love the mother load shot! How her face fades in the glass. Cool |
As for the rest of your rant. Large intercoolers are there for a few reasons. The 2 main ones that I can think of are to keep the intake charge cool which = 1) more power 2) less detonation IMO the added 5 lbs in the rear to get +40 hp and a cooler charge is well worth the sacrifice. You can shave that off and then some by swapping out the rear bumper with a FG one. |
Mr. C
* Giggles * I could not resist. BTW that does not look like a Hippie Chick, she's more of a Surf Kat.
" Mr.C " Six = Sex |
Slantnose from HELL
Let's be clear..... The BIG shiny block DOES NOT............ Make any power by itself UNLESS, (A) you have no shiny block at all. (B) the one you had that was replaced by the bigger more efficient shiny block (C) you are pushing the current turbo too hard and regardless of shiny block on not, will NOT be able to recover from the heat being generated from the over spin. (D) some catastrophic failure that has occurred in which the operator shouldn't be trying to drive the car.
The reason for a big shiny block is to allow more HP to be generated safely and attempt to keep charge temps as close to ambient as possible to help keep excessive heat related detonation (BAD) away. |
What if you use 2 med sized intercoolers on a twin?
Slantnose from HELL
Sure, RUF did the same thing on Yellowbird. I even contemplated it when building mine. I just was able to find a core that fit and do what I wanted. There is nothing wrong running separate cores per bank.
As long as they're not shiny, you are all set.
