-   -   My New 1979 930 - yes, another introduction... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/820110-my-new-1979-930-yes-another-introduction.html)
kenikh 09-02-2014 10:41 PM
The drama never ends. My injector blocks went into the parts washer...and didn't make it out. Apparently they fell apart under the strain. I can only guess that the years of heat cycles destabilized them enough that the solvent in the washer, coupled with heat and agitation, was too much. Ordered another set from Pelican, as I'm determined to complete my little injector block experiment.
al lkosmal 09-03-2014 07:59 PM
turblocks
Kenikh,
I have a used set of those somewhere at the bottom of the stash pile. If you need them to experiment with...they are yours.
regards,
Al
kenikh 09-03-2014 08:17 PM
Originally Posted by al lkosmal (Post 8244996)
Kenikh,
regards,
Al
Perchance I do, good sir. See you Tuesday?
Robbbyg 09-03-2014 08:48 PM
When finished can you post KW/HP power of your engine if possible
Im doing some numbers on before and after 930 engine work
Can you tell which is your engine when stock (going by your VIN) 180KW or 195KW ?
This stuff is good to note and gives good figures for different type of builds and outcomes
kenikh 09-03-2014 08:51 PM
Will do for sure
al lkosmal 09-03-2014 10:05 PM
blocks
I'll will be there!
al
kenikh 09-04-2014 10:44 AM
More "make it right" bits coming in via fellow Pelicans...
http://forums.pelicanparts.com/uploa...1409527847.jpg
jsveb 09-04-2014 10:57 AM
Looks good Kenik. I have one of those sitting on the shelf as well, just waiting for my car to get back.
kenikh 09-04-2014 02:02 PM
Yes, I'm a sick f#Šk...just received these little items:
http://forums.pelicanparts.com/uploa...1409864170.jpg
http://forums.pelicanparts.com/uploa...1409864185.jpg
Thermal Reactors will NOT be going on the car...they will persist as wall art, attached to the stock heat exchangers and 3LDZ turbo.
The decals, on the other hand WILL go on the car. I am a sucker for funky factory graphics. :D
dwarchi 09-05-2014 01:57 AM
Love the ol'skool turbo graphic.....that'll look cool over the sienna / sahara
Cheers
DW
kenikh 09-09-2014 12:35 PM
The 16 x 7/9 930 Fuchs are on. Will paint them later...
Bridgestone RE-11 tires.
http://forums.pelicanparts.com/uploa...1410291294.jpg
http://forums.pelicanparts.com/uploa...1410291343.jpg
confused 09-12-2014 04:44 PM
where did you get the decals?
kenikh 09-12-2014 08:00 PM
PM tomdeg
kenikh 09-13-2014 05:47 PM
Originally Posted by LuftWaffle (Post 8158695)
Bummer on the tag. Hopefully it turns out to be something like Sienna Copper Metallic! What's the interior like?
Rereading this thread, LuftWaffle called it! You must be the Hand Of God. How'd you know??? :cool::cool:
LOL.
16Volt 09-13-2014 06:48 PM
So when this thing is running again are you just going to drive it directly to the paint shop or enjoy it for a bit?
kenikh 09-13-2014 07:08 PM
Enjoy it. Plus I'll be doing all the prime and prep myself.
jpnovak 09-14-2014 06:03 AM
decals yes! exhaust logs. NO!
kenikh 09-14-2014 07:20 AM
Exhaust logs are just wall art.
LuftWaffle 09-14-2014 10:11 AM
SWAG
I really wanted to make up some elaborate story about the VIN sequence and corresponding production date falling in line with pigment delivery specific to that color at the Lesonal plant...
It's a beautiful color - congrats...
LOL.
kenikh 09-22-2014 07:19 AM
Heads, Rods and Cylinders arrived over the weekend. Now we just need to mic the rods, choose the right rod bearings and the build can begin. Getting close.
Once it starts, I'll make sure to load lots of pics.
