Performance cam for stock piston '95 3.6 rebuild?
I'm having a '95 993 3.6 engine rebuilt for a special project car. I don't need the maximum HP, but would like a little more lively response (mid to upper rpm range) and perhaps some added HP if it comes along. I want a more early period looking engine, so will probably switch to ITBs and EFI (yes, visual aesthetics are the motivation for this). Any specific recommendations for a different cam than stock? Other modest changes, ARP, etc.? I'm keeping stock pistons, so I know I have some cam limitations so I don't hit the pistons.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
It's your bicycle and you ought to do just those things that you need and not what others say you need. Presently subsequent to having said that that if it's not too much trouble, permit me to perhaps enligten you pretty much all engines. They are just a vacuum apparatus and in the event that you put in a cam that will permit more air into the chamber then you need to have a head that will permit that stream. Assuming you are happy with the force your bicycle has, a cam that is known as a drop in cam will work with your stock motor parts. I would definitely "not reuse my stock pushrods. 192.168.100.1 192.168.1.1
sorry... what????
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Try not, Do or Do not
I think we'll start seeing more posts like this....oxygen debt do to over-use of facial covering.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
As an update, I ended up having John Dougherty grind 993 Supersport cams for the engine.
Porsche fanatic
Did Dougherty use your cams as cores for a regrind? Can you post an update of what else you did and are you happy with the result? Which chip did you use?
'56 Speedster Guards Red '74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW '95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed '74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold |
I believe Herr Schimdt is correct.I have also noted a "window licking"
isssue-some trying to break it by wearing face coverings in there cars.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
