David 23's Avatar
Performance cam for stock piston '95 3.6 rebuild?
I'm having a '95 993 3.6 engine rebuilt for a special project car. I don't need the maximum HP, but would like a little more lively response (mid to upper rpm range) and perhaps some added HP if it comes along. I want a more early period looking engine, so will probably switch to ITBs and EFI (yes, visual aesthetics are the motivation for this). Any specific recommendations for a different cam than stock? Other modest changes, ARP, etc.? I'm keeping stock pistons, so I know I have some cam limitations so I don't hit the pistons.
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 05-31-2021, 04:47 PM
It's your bicycle and you ought to do just those things that you need and not what others say you need. Presently subsequent to having said that that if it's not too much trouble, permit me to perhaps enligten you pretty much all engines. They are just a vacuum apparatus and in the event that you put in a cam that will permit more air into the chamber then you need to have a head that will permit that stream. Assuming you are happy with the force your bicycle has, a cam that is known as a drop in cam will work with your stock motor parts. I would definitely "not reuse my stock pushrods. 192.168.100.1 192.168.1.1
Old 06-24-2021, 12:37 AM
sorry... what????
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-15-2021, 05:59 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by mikedsilva View Post
sorry... what????
I think we'll start seeing more posts like this....oxygen debt do to over-use of facial covering.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-15-2021, 07:25 AM
David 23's Avatar
As an update, I ended up having John Dougherty grind 993 Supersport cams for the engine.
2023. Macan
Old 07-15-2021, 08:28 PM
Porsche fanatic
jager911's Avatar
I'm in the process of rebuilding my '95 3.6L now. Looking at similar decisions of cam upgrade possibly WebCam Euro RS cam keeping the hydraulic lifters.
Did Dougherty use your cams as cores for a regrind?
Can you post an update of what else you did and are you happy with the result? Which chip did you use?
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 01-20-2022, 08:16 PM
prschmn's Avatar
I believe Herr Schimdt is correct.I have also noted a "window licking"
isssue-some trying to break it by wearing face coverings in there cars.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 01-21-2022, 07:56 AM
