Anyone with real world experience using these?
Ass-engine Nazi slot car -- PJ O'Rourke
Old 05-11-2024, 10:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Waiting for a few guys to finish engines on set me and my father have sold.
My dad ran them in a bunch of motors before releasing his final revision to the public
Old 06-20-2024, 09:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
I’ll stay tuned. Thanks!
Old 06-21-2024, 01:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
I used them for my 3.8 MFI build and made 410 hp at 11 to 1 compression on 93 octane.
Old 06-21-2024, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
JoeMag's Avatar
MST0118 - the piston pic at the beginning of this tread has inverted dome (channel between intake and exh valve), however pic in your engine post did not… Most likely because cr only 11:1 on 102’s which must not need volume on either side of channel to get cr?
Old 06-26-2024, 02:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Yes.. his pistons look more conventional to me.. not at all like Fred's design.. But I am still learning as we go...
Always learning.
www.aircooledporsches.com.au
Old 06-26-2024, 03:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Yes, my pistons probably had to have more conventional shape because had reduced compression height due to using longer rods and Xtreme heads have less chamber volume. The weight of Fred’s 98mm piston is 430 grams where my 102mm piston was 422. So, maybe these factors caused the shape to be less of a dish? There’s probably less of an advantage with dish design when piston has less dome like mine.
Old 06-28-2024, 10:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
I have a set of 98mm going into a 3.2 to make a 3.4 , comp is 10-1piston.
Measured at 9.78 deck clearance at .040", knight 75 cams , "MaxxEcu Street" Brain
Carrillo rods, should be on the dyno at the end of the month.
I forgot, PMO ITB's
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 08-07-2024, 06:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Jeff Alton's Avatar
Looking forward to seeing the results. Have the same set of pistons on our shelf....
Will go a different route ECU/CAM wise, and run on ITB's....
Cheers
www.turn3autosport.com
Old 08-07-2024, 08:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
911 tweaks's Avatar
Ian... also looking fwd to how this all shakes out...
You got this Ian & you have put in the time & have the experience & resources to achieve a great build...!!
Carry on...!!
I live for 911 tweaks...
Old 08-08-2024, 07:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
I say 183.2 RWHP
I'm not picking my nose..I'm porting my upper intake manifold.
Old 08-08-2024, 02:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
I talked to Ian this morning.. I'll up my guess to 350 HP
Old 08-12-2024, 02:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
I forgot, PMO ITB's
Ian
Well this engine fired right up this am, 2200 rpm to 2600 for 20 minutes to brake in the cam and rockers .
It is running very well, very crisp, and snappy . A little drive up and back put a huge smile on the drivers face . 315/35/17 tires on the rear .
The dyno run is set for next Monday at 8 am eastern time .
Old 08-13-2024, 06:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
911 tweaks's Avatar
Congrats… Sounds awesome…. But, we need some pics… a picture says a thousand words…
Old 08-13-2024, 07:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
A dyno chart says 2 thousand words..
Old 08-14-2024, 06:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
917_Langheck's Avatar
A video says it all....
Old 08-14-2024, 07:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Ok, the short story is , 308 hp at the crank @ 6350 rpm on the Dynojet 248 scale
I will post Dyno graphs and info shortly , the TQ is the amazing set of numbers .
All on 1.5" standard SSI heat exchangers, too small for this displacement of 3.4 ltrs
More to come
Ian
Old 08-20-2024, 09:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
911 tweaks's Avatar
Ian… Fred is looking down on you from above with a great big smile & applauding…!
Old 08-20-2024, 09:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
1.48 HP/CI, that is pretty good..
Old 08-20-2024, 12:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Well done Ian!
I look forward to seeing the dyno graphs.
More to come
Ian
Bert Jayasekera
1970 911T - Tangerine Orange
Early 911S Registry #494
R Gruppe #167
Old 08-20-2024, 03:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
