Driver's License Owner
It was the top right side. Was able to replace orings without removing the shroud. I did use a fine bead of rtv on the outside edge of washer and nut, where there is no risk of it entertaining the crank case. No leaks after cure and restart.
I thought gaskets were installed dry. So is the consensus dry or 1184 or 574?
1986 Carrera coupe - black on black 1972 CB500/4 |
Try not, Do or Do not
As a general rule, if a gasket may need to be changed or the thermal characteristics of the surfaces require movement, we use Curil "T" If the surface is stable and not likely to need replacing anytime soon, a very thin coat of 574 is applied.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
D. |
Very thin coat on both sides.....basically just wet. No bead.
Thanks Henry.
Am I correct that 574 would be preferred over 1184 for the air breather cover? This does not seem like an application where a lot of movement would be occurring for the surfaces?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Hey Buck, long time! Hope you're well. I've always used 574 for that, as have many, many others.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Hey Ed! Great to hear from you! Thanks for the info, now just waiting for the 574 to arrive so I can wrap up my project.
How about a recommendation on the plugs on the cam tower. The ones on the forward end as installed on the engine. To clarify, the same diameter as the cam bearing.
I was recommended to use 574 on that cam plug. Have not had a leak in over 20 motors.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
We use 574 there as well.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thank you Jeff.
Banned
The only issue I encountered were a few rocker shafts that "walked", and even with the RSR seals, leaked until I finally got them right.
sounds like a legit account for sure... ![]()
How hard is 574 to remove if you have a leak and need to redo a part you used it on? Say the chain housing to case area?
Racer
Main bearing web surfaces should be nothing.....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I have spent my Sunday morning skimming all 37 pages of this thread. Thanks to Henry Schmidt, CBRacerX, Wayne 962, and others who have contributed. A few questions as I am near assembling our 914-6 (aka 1969 911T) engine in 2023.
Are folks putting rubber grease on the oil pump seals?
Last edited by dennisv; 10-29-2023 at 07:57 AM.. Reason: Deleted confusing image. |
Thread Tools | |
Rate This Thread | |
