Yes, Steve R is helping from the sidelines. It was an OPC full rebuild and he supplies them so is cautious with attribution of 'blame' but is helping on the technical aspects. It was him that told me it's only truly fixable with a reseal.
My friend Peter Booth at https://www.motorscience.co.nz can help you invert your Photo and your car.
regards |
Benny Hill used to have a segment on his show from the U.K. that went "and now from Austraila)
and they would invert the camera. regards |
Try not, Do or Do not
We chose Dow 55 because of it's military application (testing and continued use). We buy it as military surplus because when we started using it, Dow 55 was not available in retail packaging.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Member 911 Anonymous
I think I missed it, but does anyone know how fast 1184 cures?
I am wondering if I should apply the 574 on saddles first or the 1184 on the perimeter first? TIA, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-11-2017 at 05:36 PM.. |
I think I did 574 first. The 1184 skims over pretty fast. Sent from my iPhone using Tapatalk
Matt. 83 911SC 85.5 944 NA - Sold |
The 574 is an anaerobic sealant (dries in the absence of air/O2) so apply it first. It won't start to harden until you clamp the case halves together.
Thank you sirs :-)
BTW, how does one keep the 1184 from squeezing into the case? I did a couple of test runs and boy the 1184 really squeezes out allot. I am not wrried about the 574 but do worry about silicon getting inside the case.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Wtd
Noticed the case thru holes only have chamfers on nut side No wonder the old orings were crushed and ripped on one side Should I chamfer the Bolt side? |
abit off center
Check the washers, as I remember half of them should have a chamfer and those go on the side of the case without a chamfer and the others should be flat?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Chamfer the holes. Use chamfered washers. Orings will be happy
Thank you Brothers
Yes all the washers are chamfered type Will be chamfering/deburring the d-side case thru holes Using this type of tool http://www.noga.com/pdfFiles/coun.pdf Last edited by DRACO A5OG; 03-12-2017 at 07:15 PM.. |
"BTW, how does one keep the 1184 from squeezing into the case? I did a couple of test runs and boy the 1184 really squeezes out allot.
I am not wrried about the 574 but do worry about silicon getting inside the case. " You just need a very thin coat but you want some squeeze out. The 1184 is not silicone RTV and it is semi-hardening and remains elastic so it doesn't break off like the silicone RTV does. It's the same stuff used to seal motorcycle cases, also sold as Hondabond 4, Yamabond, Suzukibond 4, etc. it's good stuff. |
One more, is it okay to have the 574 and 1184 contact each other, like bottom of the #1 and top of #7 bearing areas? TIA, Jim
That won't hurt anything.
Throttle Body to Intake, SEALANT or DRY?
Hey Fellas,
Besides using the new back O-ring in the Wrigtwood Kit, I assume no sealant but just want to make sure. Does anyone happen to know the torque specs for the four allen bolts TIA, Jim
Answered my own question:
No sealant just new O-ring ![]() Torque Specs, anyone anyone?
