Forced Induction Junkie
Dragon, which has four Allen bolts are you referring?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Schleprock
The throttle body screws are common M6x1.0 pan head screws that are threaded into aluminum. Snug is all you need. But if you want to be technical about it, an 8.8 class fastener that is zinc plated will normally want around 7 lb-ft of torque
http://www.metricmcc.com/catalog/Ch10/10-1027.pdf
Kevin L '86 Carrera "Larry" |
Puny Bird
Just be careful of how much you use and don't use in critical areas like the bearing saddles.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
hi
Do you put something on the o-ring of the chain tensioner ? (between chain tensionner and Cam Chain Housings)
1992 C2 964 ![]() |
Member 911 Anonymous
Yes, Dow 55 or Motor Oil. dry may pinch the o-ring.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
ok thank you Draco
1992 C2 964 ![]() |
Try not, Do or Do not
I'm not clear exactly what the difference is but I am certain that 1184 is far more resistant to "bead break-away" than the RTV products I've used. Moderation in the application (avoid excessive quantity) should be the guiding principle.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
O rings as well
Mr. Schmidt,
In your opinion, would Curil-T be acceptable for intermediate shaft cover, timing chain cover and crankcase breather? thanks
1974 Carrera 2013 VW Toureg TDI Last edited by rep; 04-18-2017 at 05:31 AM.. |
The non-drying nature of Curil T makes it easy for the gasket to squeeze out if you aren't careful. Over tightening is often the culprit. The thing about sealing these early air-cooled engines is that most ideas/techniques "can/may" work. We offer a technique that works for us. That does not mean it's the only method that works. More isn't always better, tighter is often a problem and cleanliness is paramount.
I've always (not that many engines) installed them dry with good results. Maybe I've just been lucky with the sealing surfaces. If something is used, should it be non-hardening or hardening?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Back in the early 90's Porsche was experiencing a 4% leakage rate (off the dyno) on new engines using all new parts.
We are using well testing (heat cycled) parts with the hopes that we can do the job just once. In a perfect world, a dry gasket should work. We got tired of being clobbered by an imperfect world.
Pulling my engine apart to find the cause of a leak around the nose bearing. I found this today on the cam plate. Does 574 dry into blobs like this? Maybe there is more of this around the nose bearing blocking the pressure channel
Camshaft is fine however there is some pitting on the tappets. I hope this doesn't require new tappets.
Thanks again.
1974 Carrera 2013 VW Toureg TDI Last edited by rep; 04-29-2017 at 12:41 PM.. |
Constitutional Liberal
Come on guys:
Let's try to stick to the topic. This thread is a great resource for engine sealing. Let's not fill it with off topic questions.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
The P Fix It Engine Rebuild DVD states Loctite 574 gives a 45 minute window to finish sealing the case. What it s the window with Threebond 1104, 1211 etc?
I found the 1104 started to "tack off" before I had finished spreading around the perimeter of the case. You need to work fast; aim to have it together within 5-10mins max.
Puny Bird
You must have all your ducks in a row before you start this task. All nuts, washers, seals, etc., clean and lined up, all your tools ready, torque wrench preset, etc. Think of it like a surgical procedure. I have a lot of detailed pic's of my build, but not of putting the case halves together, as there's no time to stop for a photo op. I suggest you make your own P221 rod and chain holder set like I did in the pic below, saves a lot of hassle. ![]()
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 05-01-2017 at 05:40 AM.. |
