What Is It ?
Hello guys,
I get an engine as a core.
Serial is 6660338, red fan shroud , CIS , 6 bolt crankshaft...
Any idea what is this 2.7 , 3.0 ???
Thanks!
Jim Wolf
"WHEN WE START RUNNING YOU BETTER CATCH UP"
Old 07-04-2008, 01:04 PM
A third digit of 8, 9, 0 or 1 would be a '78-'81 3.0L. I would imagine that a 6 would indicate a '76 which would be a 2.7L.
The distributor on the 3.0L SC engines turns counterclockwise. Others turn clockwise. You could check that.
Old 07-04-2008, 02:49 PM
Thanks Brian,
I take a look in the LH crankcase : 930.101.104.0R
Thanks!
Jim
Jim Wolf
Old 07-04-2008, 02:58 PM
Originally Posted by Jim Wolf View Post
Hello guys,
Thanks!
Look at the engine type number stamped on the the case just to the right of the fan housing next to the cam tower oil line.
If its a 2.7, you'll see a 911/xx. If its a 3.0, it will read 930/xx. The last two digits tell you what it is.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-04-2008, 09:24 PM
Bill Verburg's Avatar
I recognize that #
it's a 1976 Carrera 3.0, 930/02. They used #s 666 0001 >>
the other Carrera engine for that year was the 2.7 911/83 which had #s 666 8001 >>
Bill Verburg
Old 07-05-2008, 05:52 AM
Thanks Bill!
So, this engine has a 70.4mm crank but with 6-bolts instead of 9 correct ?
Thanks!
Jim
Jim Wolf
Old 07-05-2008, 12:10 PM
Thanks Bill!
Thanks!
Jim
Carrera 3.0 motors all had 6-bolt cranks.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-05-2008, 01:40 PM
Thanks Steve!
Jim Wolf
Old 07-05-2008, 02:06 PM
