Drive it like u stole it.
Ok, I received my Porsche COP Beru coil. The biggest issue I see is that the coil part and mounting holes are not flush with the valve cover. The spark plugs are not perpendicular with the surface of the valve cover so some sort of adapter would have to be made to properly secure the coils to the valve cover. Also the PORSCHE logo on the uppers adds to the problem. I can now see that a full billet valve cover with proper mounting points would be optimum. I have not tried them on the lower plugs of my Twin plug engine yet.
As for the Denso coils, I wonder if the spark energy is sufficient to fire off a boosted engine properly? The coil is rather small on those.
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Gon fix it with me hammer
Does anybody know the Kawa Part number for these Cop's?
And what are they normally going for new? Are they sensitive to plug fouling when used in an engine with rich mixture ( like MFI)
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Forced Induction Junkie
Thanks for the manual pages. The unknown factor is the Item 'C' (Peak Voltage Adapter) mentioned in the procedure. This adapter reduces the voltage output so it can be measured on a standard analog VOM. It's probably in the area of 300-400:1 reduction to get 85 readout on the VOM.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
www.competitiondata.com |
No, not really sure. I just noticed that the illustration showed an analog volt meter which are pretty basic. You may be right that it is some kind of peak-and-capture circuit.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P Last edited by WERK I; 11-24-2009 at 10:25 AM.. |
Santa Clarita, Ca.
Am I ever glad I started this thread! I've been soaking all this up. You guys are amazing. But, I'm still trying to figure out from the replies if anybody has actually got a running system from using the Kawasaki coil packs. If you do can you please post a detail of the components and wiring? If the data is clear enough I'd be happy to generate a wiring schematic.
..................maybe I need to start an FI thread now. |
Certified User
Any updates?
I am still tossing up which way to go with my COPs on a 964 engine. I'd love to see a few more pics of some setups on any engine.
My current options are to go with the Audi coils (questionable reliability) or Toyota coils ($$). I also don't have enough technical info on the Toyota coils to commit just yet even though I have already scored one set of six for free. Whichever coils I use, they will be driven by Megasquirt ECU so I want to stick with something that will work with a 5V or 12V signal. So, any updates on COP applications?
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Cop
Can you show/explain how you are driving these Kawa coils? Unless I am interpreting this incorrectly, the manual shows that they are driven by fairly high voltage (88VDC+). Can you share with us how you provide the primary voltage or is there another way......or did you just provide 12VDC and they worked? Pix? Regards, Al PS: I've got a box of these too!
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Certified User
+1 on the operating voltage for the ZX600 coils.
This issue has been raised earlier in this thread (and others) but no-one has ever described how they need to be hooked up so I crossed them off my list. Anyone with a wiring diagram to share will go on my Xmas card list for next year.
Senior Advisor
Al, have you tried to get a 12v signal to the COP with a plug installed to see if it fires? I might make a test stand to get all the components working prior to changing out my system.
08 Cayenne Turbo |
signing-up.
Jon |
James,
I have not done that yet, but the thought has crossed my mind, as well. I need to finish my current project, but that one is working itself up in the que. Let me know what you find out..and/or if you need help, let me know. Al
Senior Advisor
I'm going to try one, there cheap and if it works, i'll go for it also
08 Cayenne Turbo |
James,
I have extra(s). I'd donate 1 or two to the test, if that helps. Al
Certified User
Gotta keep this thread alive. C'mon guys, let's see your COPs. Pics, details, wiring, mounting, ...
I have just tested one of the Toyota coils I might use. These coils have four wires. Two are a little larger so I assumed they were the 12V+ and 12V- to power the coil. By default, the other two wires must be the signal from the ECU. I had a guess as to which was +ve and which was -ve. Got it wrong but fortunately it didn't do any harm to the coil. It just didn't fire when the signal polarity was the wrong way around. My other gamble was whether the signal was 5V or 12V (or 88V!). As it happens, the coil seems to work fine with 12v signal. To test, I hooked up the two coil power wires direct to a battery and also earthed the coil's -ve signal wire. I connected a metal file to the battery +ve and then lightly stroked the coil's +ve signal wire along the file. This produced a nice fat continuous spark. No rocket science here, but now I know that my Toyota coil seems to work OK with 12V signal and hooking it up with reversed polarity doesn't fry its innards. ![]() Al, James, I hope this gives you some ideas.
Bill,
That is great and the results look positive. Thanks for that and please keep us updated on your testing. I am focused on finishing my 71E project, but after that I will be turning towards this. al
![]() I would like to try the Kawasaki Denso coils as the fitment is so good. Has anyone done further testing done on these?
Kawa
The KAWA coils that I have purchased have a Mitsubishi logo (3-diamonds) on them.
The Kawasaki coils that I picked up have the Mitsubishi logo (3-diamonds) on them also with a part# 61560 / 7125
