millhaus's Avatar
SC cams mod on a 930 motor?
I am rebuilding my stock 1980 930 engine. I was going to just rebuld it back stock but I was wondering if I will regret not installing SC cams. I want to keep the stock CIS and fuel delivery system for now (due to budget).
Are the SC cams with stock CIS worth it from a noticable low end performance upgrade? (I do have a k27 with a 1 bar spring as well.) Can you tune the CIS system enough to accept the SC cam? (fuel/air delivery, etc..)
Stay stock or upgrade to SC cams?
Millhaus
Old 12-13-2009, 12:17 PM
totle's Avatar
Hi Millhaus,
I am going the same route now. I have been recommended to go for SC cams in my 930.
This will be noticable low end performance and drop around 5500 rpm as I understand.
There is alot of threads here explaining this.
Old 12-13-2009, 02:39 PM
Certified User
billjam's Avatar
Try this link. I documented this process when I did it a year or so ago.
The change to SC cams is well worth doing.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 12-13-2009, 03:43 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I have always thought the SC cams
were the best bang for the buck when it comes to stock 930 updates.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-13-2009, 04:16 PM
camgrinder's Avatar
Originally Posted by henry schmidt View Post
i have always thought the sc cams
+1
John Dougherty
Dougherty Racing Cams
Old 12-14-2009, 09:01 AM
Chain fence eating turbo
All my 3.2L engine has that isn't stock is SC cams, 930 jugs and slugs, and a single T60-1/0.85 AR turbo.
It has dyno'd from 427-447 wheel hp @ 1 bar.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-15-2009, 04:04 PM
millhaus's Avatar
Tippy,
Are you running an intercooler with that set up? Stock 930 or aftermarket?
Sounds awesome
Millhaus
Old 12-15-2009, 06:58 PM
Originally Posted by millhaus View Post
Tippy,
Sounds awesome
Yes. Not sure of brand honestly. I bought the car this way from a friend. I have never looked or seen the brand of the IC.
Here is a pic:
Old 12-16-2009, 06:03 PM
millhaus's Avatar
SC cam vs 964
I have heard many talk about the SC cam upgrade as being the best bang for the buck on a 930 rebuild but others have mentioned the 964 cam.
Any opinions? What are the benefits of both?
Millhaus
Old 12-21-2009, 05:33 PM
lite75's Avatar
Running 964 cams, they pull much harder in the upper RPM range over the stock ones. Work well with cis or efi, a bit more aggressive than SC cams.
75 930, 76 930, 83 SC EFI turbo
Old 12-21-2009, 09:15 PM
