9:00 am? Slackers
Real pours start at 5:00 am.
Old 11-28-2017, 01:43 PM
908/930's Avatar
Gives you lots of time to get a couple 10 ft lengths of 5/8 rebar and set them near where your lift pads will be, stretching from front to back.
Old 11-28-2017, 03:38 PM
rfuerst911sc's Avatar
Hey Paul it's 6:45 as I'm typing this and it's still pitch black out ! But I did get a text last night stating the truck will be coming at 8:00 vs. 9:00 so that's good . Weather forecast for today/tonight is good and warmer than it has been so much less of a chance for frost . Might get a light rain tomorrow but it's under roof other than the front entry apron . Really looking forward to getting this portion of the build done !
Old 11-29-2017, 03:49 AM
A little over 16 yards of concrete is sitting there slowly drying waiting to be finished . So far no surprises and my DIY concrete forms are holding ! I have taken some pics will try to post tonight or tomorrow .
Old 11-29-2017, 07:41 AM
You're probably poured out by now.
Hope it went will.
Pictures damnit!
Old 11-29-2017, 07:46 AM
OK OK Here are two pics I just downloaded . Power trowel put down a nice smooth finish I will probably seal the floor this weekend before I get it dirty Relief cuts are done I think it came out great . Nice group of guys they were fun to hang out with .
Old 11-29-2017, 01:50 PM
A few more .
Old 11-29-2017, 02:02 PM
You want to keep the moisture in the concrete, not "push it out." There are curing products that are applied like a sealer that would be a good idea at this stage. Otherwise, keep it soaking wet and keep it covered. Keep the forms in place, too.
Old 11-29-2017, 02:16 PM
You can seal it right away if you use the correct sealer . Per the concrete dude if you use a " curing " sealer you are good to go the next day if you want to . If you use something like Thompson's water seal he said wait 30 - 45 days . Tomorrow I will breakdown the forms and go purchase the sealer and some 2 x 6's . Depending on the weather will seal on Friday and start studding walls on Saturday .
Old 11-29-2017, 02:23 PM
Do yourself a favor and get some water on the concrete. Concreted cured while remaining wet can have around a 50% increase in ultimate strength over concrete that is not cured that way. I wouldn't be in a hurry to remove the forms, they are beneficial to the curing process.
Old 11-29-2017, 02:40 PM
Leaving the forms on for a few days does make sense , I'm guessing it slows down the evaporation of the water allowing a harder setup . Tomorrow I am going to give it a bath with a garden hose to clean up the saw cut dust and to keep it moist .
Old 11-29-2017, 03:11 PM
Here's a little basic info on concrete curing that you might find helpful:
Role of Concrete Curing
Old 11-29-2017, 03:34 PM
Are your poles directly set in the concrete?
Old 11-29-2017, 04:54 PM
MBAtarga's Avatar
I ran a sprinkler over my shop pad daily for the first week - even though the pour was in early September and temperatures were moderate. Never had the first crack show up.
Mark
'83 SC Targa - since 5/5/2001
Old 11-29-2017, 05:04 PM
Paul when the pole barn was originally installed one bag of concrete went into each hole after the pole was put in . I nailed my 2x6 form boards directly to the outside of the poles . So the floor pour concrete encapsulates three sides of each pole .
Old 11-30-2017, 12:53 PM
Because I'm now retired ( it was official this morning ) I am dousing with garden hose every few hours . It has been raining here in Dahlonega for the past hour so that is helping also . This morning I picked up some curing sealer I think I'll water for a few more days then get the sealer down . I'm straining at the leash to get framing
Old 11-30-2017, 12:57 PM
There's pros and cons about posts in concrete. Let Google be your friend and look it up.
But it's too late now.
Old 11-30-2017, 01:48 PM
Yep I'm over the falls so really not an issue . Hey if I get 30 years out of it that will probably outlive me !
Old 11-30-2017, 01:59 PM
Another step forward today I applied the " curing sealer " . Used a garden sprayer and followed the manufacturers instructions no big deal . Tomorrow I break down the forms and start the real work
Old 12-02-2017, 01:28 PM
I'm still here guys but haven't done anything picture worthy yet I have enclosed the bottom of the laminated beams with 2x10's so I have something to nail to when I install the walls . And the end rafters at the bottom I have added two layers of 2x4's making them 4 1/2 inches thick so my wall top plates have some meat to nail to . In a few minutes I'm off to purchase the majority of 2x6's for the walls . Today is the last warm day here for a couple of days so we'll see how far I can get . I hate working outside when it's cold , yep I'm a cold wimp
Old 12-05-2017, 04:26 AM
