No power to starter after sitting
Hey Guys-
Tried to turn the car over yesterday after a long hiatus of not driving it for a year. Batter was dead so I put a charger on it. I turned the key and got dash lights but no crank. Then nothing, no dash lights, no crank, no fuel pump. Replaced the battery with a new one and now nothing from the switch at all. No life. Any thoughts? My first thought is its a coincidental ignition switch failure but I don't know what else to check. How can I test the switch. I don't know which pins are which. HELP E
1969 911 Outlaw 2.2T |
Probably should look at the fuse panel and do a continuity check. Is power getting anywhere to the car.
Some are switched when the ignition is in the accessory position (ACC) , others both ACC and RUN positions. You'll need a manual with electrical diagrams. Yes you may have a bad switch, and checking continuity at the fuse panel will be the first indicator. But I'd also watch out for hidden shorts while you are doing this. Certainly don't want you to have a fire.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
Wiggle yellow and yellow/white wire connections at starter solenoid....by hand (not pliers) so long as your battery is connected.
With a circuit diagram (one available on the Pelican website for early cars like yours) you can figure out which fuses in the panel in the trunk are always hot, and which are switched. First off, check to see that you have 12-13 volts from the battery plus to a ground (not the battery). That is a rough check for whether the battery ground is good.
Then start checking the various large red wires which connect to the top of the fuse holders for 12-13 volts. Some of these are "always on." If none are, perhaps the positive clamp which attachés to the battery is bad. It can happen - corrosion can get in there, and not all crimps are created equal. |
A master mechanic much wiser then me has told me to conduct a thorough check of the battery condition and critical grounds before jumping to the complicated stuff.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Fleabit peanut monkey
Grounds are underrated.
1981 911SC Targa |
check the battery connections, actually clean them.
clean the chassis ground and if needed clean the one from the body to tranny
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
I'm thinking it's time to call AAA.
Haven’t the wiring diagrams been removed from Pelican?
1966 912 to 2.7 Frankencar |
Check the plug connector in the engine bay for power and continuity.
3.3 ltr, stock compression, efi, twin turbo - no intercooler. |
as mentioned above by t77...ground from transmission to body..
this one
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
check your 14 pin connector (unplug and plug back in)
Hahaha, good German metal!
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery.
pm sent.
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Tags |
battery , electrical , ignition switch |
