Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Project Outline and plan:
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-02-2020, 01:27 AM
Rennch on YouTube
rennch's Avatar
Front Bumper Rust Repair and cutting into the custom race "nose" of the car to fit the front fenders.
Michael O'Neal -
Old 04-02-2020, 01:28 AM
Rennch on YouTube
rennch's Avatar
The Restoration Design panels have arrived! Initial fit of the rear quarters, and stripping off some of the race bits to make them work.
Michael O'Neal -
Old 04-02-2020, 01:33 AM
Rennch on YouTube
rennch's Avatar
Rear Panel Install Part 1!
Michael O'Neal -
Old 04-02-2020, 01:34 AM
Rennch on YouTube
rennch's Avatar
Rear Latch Panel Part 2!
Michael O'Neal -
Rennch on YouTube
rennch's Avatar
Final Quarter Panel Fitment, Passenger Side!
Michael O'Neal -
Old 04-02-2020, 01:35 AM
Rennch on YouTube
rennch's Avatar
Finished off with some weld thru primer today.
Michael O'Neal -
Old 04-02-2020, 08:19 AM
Cory M's Avatar
Originally Posted by emptyo View Post
Also..I'm not exactly sure what to do about the existing lead filler. I may need to delete some of it so I can get to the metal to weld it. On the grey ghost, I hit it with a propane torch and it melted away. I'm planning on doing lead filler on this car for the drip rail delete, so I could probably do it here as well.
You don't want to put plastic filler over the lead. So you'll either need to remove it with a torch or use lead filler.
Old 04-02-2020, 10:42 AM
Rennch on YouTube
rennch's Avatar
Yea...that's what I was thinking too. Plus I want to learn lead filling...I think it's a lost art.
Michael O'Neal -
Old 04-02-2020, 11:25 AM
Zeke's Avatar
I just saw this car in person and it's the real deal although I don't envy the amount of work ahead.
And money.
But if it turns out to be close to the concept it will be a world class build.
Old 04-08-2020, 11:05 AM
Rennch on YouTube
rennch's Avatar
And money.
Thanks Milt. Nice seeing you IRL (we kept 6 feet apart).
I'm hoping because it's going to be mostly DIY that it won't be a tremendous amount of money. Famous last words.
Michael O'Neal -
Old 04-08-2020, 11:26 AM
Rennch on YouTube
rennch's Avatar
I've just uploaded the latest video of my 69 911S Blasphemy Build, where I try to figure out if I can use my flux core welder to patch some unseen body panels.
Michael O'Neal -
Old 04-22-2020, 07:58 PM
Rennch on YouTube
rennch's Avatar
Posted another video today wrapping up the fabrication and install of the passenger side kidney piece, and rocker panel patches.
I coated the inside with POR15 (thanks Zeke) and then finished it off with my signature pigeon poop welds.
First I used my propane torch to burn off the lead filler and give me something solid to weld on.
I made a couple of rust repair panels and was able to weld them on before grinding everything down and coating it with POR15.
Michael O'Neal -
Old 04-26-2020, 12:35 AM
Rennch on YouTube
rennch's Avatar
If you prefer the video...
Michael O'Neal -
Old 04-26-2020, 12:46 AM
Rennch on YouTube
rennch's Avatar
Today I tackled more chassis restoration, and I had to use a bottle jack to spread my rear frame rails! The full roll cage of this car had "compressed" the frame rails a few mm, and my replacement panel from Restoration Design was a good 1/2" off from being able to be installed.
This was the jack I eventually used, with a 2x4 against the opposite frame rail.
I was able to use one of my regular floor jacks as a "proof of concept" and got the piece in for measurement.
Quick test fit of the outer rear latch panel piece.
Michael O'Neal -
Old 04-29-2020, 11:39 AM
Rennch on YouTube
rennch's Avatar
After welding it on and cleaning up the welds.
Then sealed up with a bit of POR15 as a stage 1.
Am excited to get that rear panel on so I can finally fit the quarters.
If you want to see the video of this whole process, here it is:
Michael O'Neal -
Old 04-29-2020, 11:40 AM
Rennch on YouTube
rennch's Avatar
I'm just about to fully weld up my quarter panels and rear latch panel. I am borrowing a stock set of right and left bumpers to help dial in my alignment, but I'm curious what the general procedure is for ensuring panel gaps, especially around the doors, are spot on.
Here's where I am at the mo:
My plan is to use lead filler where the factory did, but I'm most concerned, like I said, about panel gaps. What are the techniques to dial in my door gaps correctly?
Michael O'Neal -
Old 05-17-2020, 05:25 PM
Rennch on YouTube
rennch's Avatar
Just uploaded a video on my quarter panel install!
Michael O'Neal -
Old 05-18-2020, 02:39 PM
Registered Minimalist
75 911s's Avatar
Great job Michael. Your perseverance is paying off. It's starting to look like a car again.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 05-19-2020, 06:34 AM
You need to hang doors before permanently welding outer sills(rockers) The whole shell fitment really revolves around door pillars.if you can get door fitting flush, this will help with rocker fitment.I once made error of fitting rockers (not 911) that sat so proud of door I had to cut them off and start again.Get the doors as close as you can then its shims, and hammers jammed in hinges.
Old 05-19-2020, 03:31 PM
Tags
build thread
