Convex side mirror
Is there a convex passenger side mirror prong-type option for my '86? Thanks
Old 01-05-2020, 07:38 AM
Would be interested also. Thanks!
Old 01-05-2020, 08:15 AM
kent olsen's Avatar
I put one on my drivers side, not a stock mirror. I wanted something to give me more side vision while on the track during a track day. It does that, but what I don't like is everything looks smaller and unless the car is close it's hard to distinguish.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 01-05-2020, 08:36 AM
My harley came with those things. Talk about unsafe. 1st thing that got replaced. Nice to know exactly where that car is, rather than have to guess.
206 637 4071
Old 01-05-2020, 08:45 AM
Where did you get the mirror from? How did you mount it?
Old 01-05-2020, 10:06 AM
check out these guys -- https://www.only944.com/partscatalog/only/mirrors/mirror944/
944 flag mirrors use the same size glass as 911 flag mirrors -- these guys sell convex glass which you can glue over your flat mirror glass OR, carefully pry the flat glass off the mounting backing and replace (the better option as the glue holding the mirror glass onto the backing becomes brittle and fails with age
Old 01-05-2020, 02:39 PM
I bought one from our host 4 or 5 years ago; not sure this is the same, but it is listed here.
https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_BDYEXT_pg5.htm#item9
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 01-05-2020, 03:33 PM
I bought a stick on wide angle mirror 24 years ago and after 100,000 miles and temps from 0 to 121 F it has been a stick on and forget it thing. Even when the mirror heaters are on it sill melts ice off of the mirror just fine. I think I still have the information of where I bough it all those years ago.
It was a super simple install. Clean the old mirror, peel and stick. Ta Da.
Old 01-06-2020, 06:41 AM
Thanks a lot guys!
Old 01-06-2020, 07:54 AM
I bought this from Burco Redi-Cuts.
I just double sided taped it as I didn't want to ruin the heated mirror if I broke something trying to retro-fit.
Works like a charm.
3 11/16 X 6 9/16
6 7/8 dg
#3614
Convex
Non-heated mirror
Fits heated OE mirror only
Old 01-06-2020, 11:54 AM
Works like a charm.
3 11/16 X 6 9/16
6 7/8 dg
#3614
Convex
Non-heated mirror
I ordered it. Let's wait and see. What kind of tape did you use?
Old 01-11-2020, 06:52 AM
mak -- I'd first make sure your existing mirror glass is still SECURELY fastened to its backing -- had my original passenger mirror glass literally fall off its backing at a stop sign a few years ago -- chain only as strong as its weakest link, etc.
Old 01-11-2020, 07:22 AM
FrenchToast's Avatar
Convex passenger side mirror was made standard in MY1988 or 89. One of those, don't remember.
It's listed in the PET.
Old 01-11-2020, 02:47 PM
speednme1's Avatar
I had a couple for sale but they are sold now. The part number is on my ad FS: NOS Convex Mirrors for Flag Door Mirror housing
Rey....77 930 "the Mistress"
Old 01-12-2020, 06:10 PM
I have an '88 with plain glass so most likey '89
I used think double sided tape with a foam core. It's probably no more than 1.5 mm thick.
Old 01-13-2020, 11:58 AM
