Dave |
Author of "101 Projects"
![]() Your suggestion regarding the Singer take-offs is a good one. I'm assuming that the guy with all of the Singer parts is this guy? I mean, who really has 76 of these units, unless you've been buying them off of Singer? He's also located right here in SoCal -> two pretty big clues there. Tomorrow I will readjust the wiper on there and button the unit back up. Pretty disappointing, as I'm quite sure that this unit is not the one that I gave with the engine (that only had 65,000 or so miles on it). In the meantime, I will try to source a new AFM that hasn't been messed with. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne i`m a little too far but i can give you a unit for free -i have 4 - but it will take a little time with the post....let me know if you like it later ,problem ,you would just pay for the postage....i guess it would take a week with DHL?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
-Wayne
I have the same issue : AFM tracks worn to substrate. I have tried retracking them and it 'looks' Ok on the scope but with the engine running there are dips and peaks (even on idle) resulting in a small hesitation. Due to COVID, I am unable to do a test drive (it is still forbidden to drive classic cars in BE 'for leisure'). If the retracking doesn't work out, I will be looking for a replacement unit soon. If you decide to sell any of the units, plz contact me. @SteveW : I see that the output of the AFM (pin 7 ECU) goes straight into the multiplexer and then the A/D converter. So somewhere in the EEPROM there must be a mapping table for the input ? Can this be used/remapped to make the ECU work with the 'aliexpress' replacement boards for the AFM ? Or is it impossible to recalibrate perfectly ? Kind regards, FrankM from Belgium
__________________ 1985 Carrera 3.2 |
I might have one also. Did mention that in post #8.
Yes, it can be re-coded if you disassemble the original Bosch EPROM code and re-write it in 8051 assembly language. Also not that difficult if you have the Intel 8051 compiler and can write C code. If you have access to an old PC with DOS, there's an assembler in it you can use to write the code in assembly language. Good luck!
Dave Last edited by mysocal911; 05-15-2020 at 06:02 AM.. |
Steve, I was not aware that the 964 unit is a drop-in replacement? Is this really the case? And yes, Autobahn in LA is where all the Singer take-offs go, I bought some 964 calipers from them. Nice guys and they are willing to deal on the prices somewhat
Bill Last edited by wjdunham; 05-15-2020 at 06:44 AM.. |
really that important. Had the cover off my 964 AFM and noticed it has a set of three contacts on the copper wiper unit instead just two on your 3.2 AFM. I know the two units are interchangeable, but there is that subtle difference. Three contacts surely offer better redundancy than two.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Thx, Wayne
I'm not sure how susceptible the ECU would be to noise in the AFM? I've never seen another scope trace of an AFM while the engine is running, so I don't know if this is typical / normal, or if this is an issue? Thoughts? -Wayne
Wayne, this thread will be a gold mine to future trouble shooters. And somehow it makes me feel a little better as a guy scratching his head when my 3.2 runs a little or a lot funny. After 25 years of driving my 911 I have come across most issues and helped fund your hobby with a lot of parts buying.
You are way more experienced than most of the other guys posting on Pelican. And some of the top experts have chimed in. I am following along to see just what is the culprit. My coil caused me some real headaches, and until I replaced it with a old black Bosch coil did that issue go away. You have replaced the coil and tried all the logical things. Good luck finding that gremlin, and I look forward to seeing the solution and your cool 914 back on the road.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Mine has spikes too, but also slight hesitations in idle... https://youtu.be/C2qnNGzoXrs Sent from my iPhone using Tapatalk
Move the tip inward maybe about 1mm, and angle the wiper tip to maintain the same angle it had originally to the carbon track. Also adjust the wiper pressure so it has just enough pressure to maintain contact, so as when it just makes contact give just enough pressure for the wiper to deflect another 1 to 1.5mm of pressure. Too much pressure accelerates wear of the carbon, which you don't want. The arm should be positioned a couple of mm higher up on the pivot hinge than before in order to allow the tip to come inward. If you have a contact enhancer, lube and treat the track with it. I always use a DeoxIT pen on those. But your meter could be at the point of no return. It's also a bit questionable that half your wiper tip is off track completely, as if someone loosened that philips screw and repositioned the angle more clockwise to address a rich issue. They usually should not be that far off track, and most of the time are usually all on the carbon track when parked. Porsche superceded the AFMs on the 3.2s to a 964 part number. A few years ago, Porsche offered replacement AFMs on an exchange basis for something like $700. No idea who redoes them for Porsche. The 964 units do all have a triple tip wiper tip, along with a reduntant wire from the wiper arm to the copper wiper bridge contact above it to reduce noise and resistance. The triple tip AFM can be found on some of the later 89 3.2s. These units do seem for some reason to exhibit less wear over time then seen on the 3.2 units, most of the time they look really good. Whether the calibration is the same, I'm not absolutely sure. The last 964 unit I tested seemed to have noticeably tighter spring tension than the one on my 86, and the throttle response also seems to be not as sharp. I ended up recalibrating it, loosening the tension to be the same as on my 3.2, I forget but I think by about 4 or 5 teeth, which brought the response to where it was equal. Autobahn is where a lot of the Singer parts get sold to. You could contact them directly and speak to Mike who's in charge of those parts. Last edited by Steve W; 05-15-2020 at 12:16 PM.. |
I saw a fairly well-done video last night that showed how someone "updated" their AFM with an attachment wire very similar to the one shown on your 964 AFM. I thought it looked a little "ghetto", but now I see the same exact thing on your 964 AFM here! I wonder if this was factory, or if these were updated by someone at some time.
Actually, here is the video: -Wayne
I will try to move it to a new section and see if that makes a difference, while moving to get one of those 964 Singer take-off units. It is interesting that there was an original 930 part number that then got superseded to a 964 part number, but the internal BOSCH number remained the same on both of those units. Something is a bit odd about that - I'm quite familiar with the way Porsche performs supersessions, but not so much on BOSCH. The 3-contact 964 unit *should* be a separate part number if done "the Porsche way", as it's an updated (and presumably more reliable design). Also, in the back of my mind, I would think that the displacement increase of the 3.6 versus the 3.2 (more than 10% difference) would mean that the airflow would be greater through the 3.6 engine than the 3.2. That would mean that the effective range of the unit would be less for the 3.6 if the two AFM units were exactly the same (the flapper box would max out opening / pushing against the barn door screen sooner than on the 3.2, resulting in a more limited range of the box). If BOSCH increased the spring tension on the door to compensate, that would make sense, although technically that *should* not be the same part number. Who knows, it could be either one... -Wayne
My AFM came from a 10k mi unmolested 964 3.6 and was sealed as new.
BTW if you ever fix this thing, the next thing you should address is the clusterfuch of elbows om your intake. From dyno testing every 90 degree bend kills power by 4 hp to the wheels, and the one from your air filter to the AFM is horrible, at least a 10hp killer!
Gosh, things are so much easier these days with libraries, and modules, and apps, and graphical user interfaces, etc. And compilers! As expected, *none* of the high school girls were ever impressed with *any* of this stuff... -Wayne
