Did I buy the right headers size?
I have a stock Row 84 Carrera with a 3.2 that I'm upgrading the exhaust on. So the general consensus is that I needed 1 5/8 size headers for the 3.2. Recently I purchased a set of headers and Im not 100% sure if I bought the correct size. They do measure 1 5/8in on the outside diameter however inside diamter is 1 1/2in. Did I screw up or are these the correct ones for me? Thanks
1984 RoW slicktop Porsche 911 Carrera RUF tribute - 2003 Bentley Arnage R
1997 Mercedes Benz G320 - 1972 Datsun 240z - 1991 Dodge Ram D350 Cummins - 1972 Cadillac Coupe DeVille
IG: righteousrags89
Old 10-28-2020, 05:17 PM
Racer
winders's Avatar
Headers are tubing so they are measured by O.D. Yes, 1 5/8ths is a good size for the 3.2L engine.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 10-28-2020, 05:27 PM
Old 10-28-2020, 05:41 PM
So to clarify, whenever a manufacturer states the size its always O.D. and never I.D. correct?
IG: righteousrags89
Old 10-28-2020, 05:55 PM
Walt Fricke's Avatar
Tubing is normally specified as OD plus wall thickness. Like 1.75 x 0.90 for a common roll cage tubing size.
Old 10-28-2020, 06:05 PM
Racer
winders's Avatar
Yes, correct.
Scott Winders
PCA GT3 #3
Old 10-28-2020, 06:19 PM
Did you mean to say ID plus wall thickness? because otherwise wouldnt the OD already account for the wall thicknes?
Let me rephrase my original question; Since my ID is 1.5" and OD 1 5/8" would they still be considered as "1 5/8in" headers thereby making it the correct headers for my 3.2?
IG: righteousrags89
Old 10-28-2020, 06:20 PM
I apologize if I sound thick headed
IG: righteousrags89
Old 10-28-2020, 06:21 PM
Racer
winders's Avatar
To be clear, tubing is specified by O.D. *and* wall thickness.
I have yet to see a header manufacturer specify wall thickness unless asked.
Scott Winders
PCA GT3 #3
Old 10-28-2020, 06:23 PM
Racer
winders's Avatar
No, you don't. Just remember that headers are measure by the O.D. so your headers are 1 5/8ths.
Scott Winders
PCA GT3 #3
Old 10-28-2020, 06:55 PM
Thank You @winders
Thread/End
IG: righteousrags89
Old 10-28-2020, 07:01 PM
Crotchety Old Bastard
RarlyL8's Avatar
It is good to note wall thickness as different materials may use significantly different wall thickness. For example, our 321 stainless headers use 0.049" wall thickness due to the strength and heat tolerance of the material. Most 304 headers use 0.065" and some mild steel headers can go up to 0.125". This is a tremendous difference in ID, let alone weight. The exhaust port size on the 3.2L Carrera engine most closely matches the 38mm ID typical of 1-5/8" stainless headers, which is why 1.5" primary SSI and headers are considered too small for that application.
Old 10-29-2020, 05:31 AM
