What not to do when building an engine.
My customer bought an engine 3.6L built with RSR cams. It froze up 3000 miles later and he brought it to me to tell him what went wrong.
Too much silicone being used everywhere. Note the excessive use of black silicone filling up the rocker shaft holes making it impossible to now remove the rockers. Bit of silicone broke off blocking oil passages leading to oil starvation which spun the number 3 rod bearing and likely bent the crank. Whoever did this had no business building engine.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
When you think you have seen it all.
Walt 82SC 3.0 81SC 3.6 |
1978 911 SC
Looks similar to the "NEW REBUILT" engine I purchased from forum member couple months back.. Everyone claims to be engine builder these days... great picture showing what not to do. Crazy.
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler. |
Banned
Where does the mindset of using silicone everywhere come from? Do people just naturally assume since they used silicone caulk on their shower that they should use it in other places for sealing?
Those rocker shafts make me want to puke. |
rebuilt engine
Seems to be going around.....here's some pix of the rockers on a 3.0 that was sent to me to figure out why it was making bad, banging noises......
The 1st pic shows the same use of silicone to seal the rockers.....will be a beeeyatch to get those out of there......also some sticks/sawdust stuck to the gasket......but the 2nd pic shows the winner....pistons installed rotated 180 degrees out. Pretty sure that is the cause of the bad noises..... ![]() ![]()
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Yep same wonkiness going on with this 3.0. Besides loving red RTV and using lower allen bolts instead of studs I just uncovered this:
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
we have some schmucks here in Czech too;-)
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 06-21-2023 at 07:48 AM.. |
here some genius helped himself with a stretched chains...welded some extra on the arms to cover the space...oh ya the chain was rubbing on top a little..That was 911 imported from over the pond.....
Ivan [IMG] ![]()
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 06-21-2023 at 07:56 AM.. |
Woooooooooooooow.
Brewster Green 1977 911S Outlaw Hot 2.7|10.5:1|Single Plug|Knightrace Cams|Weber IDA40's|SSI's|MSD Ignition Engine Built by Will Pyle Instagram: indy.alex.g |
gearhead
Seen that waaaaay too many times over the years.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Behind the Sun
Top Dollar
One of Kind Unobtainable They don't make them anymore. You won't find another one this condition Has all the paperwork Blah Blah Blah. I feel sorry for your customer. |
Original Owner
Its these peeps think they can R&R rocker shaft seals with the engine in the car...and then they give up and stuff the rocker shaft recesses with silicone.....
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
I have added them with engine in situ. It can be done correctly.
for the record i replaced all my rocker shafts with the engine still in the car. I had the exhaust off to upgrade to SSI anyway . Upper back couple were finicky , bot other than that, not too bad.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Still here
PCA Member since 1988
Likewise here. I did it a few months ago with the engine in the car, and it was a PITA to get those suckers back in with the RSR seals on them, but a couple thousand miles later, they aren't leaking, so I must have done something right.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
1978 911 SC
Yes it was... insert face palm here...hah
Wow...
I'll admit that I've rebuilt only two auto engines (one a 327 Chevy and the other my 2.7). Each was a very different animal. In both cases I did a ton of research and reading first to understand what to do (and more importantly what NOT to do). Lots of great info here and in many books related to proper sealing and assembly of 911 engines. There is no excuse for what is seen in those photos... |
As a former mechanic, and engine builder, looking at this I despair;
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Holy hell, when I saw the late model cams with the early big nut and washer with a bolt and spacer, I have to think that the guy never even bothered to look up the prices of the parts to do the job right. For about $30 he could have done it the right way.
Thread Tools | |
Rate This Thread | |
