Senior Member
ohecht's Avatar
Bench-testing alternator
My alternator is out of the car and has suffered a small fall onto the back of the unit.
I would like to test it, or at least verify the integrity of the connections, before reinstalling it.
Is there a way to do this? What tests and values should I look for among the connections if it is possible?
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 12-20-2003, 05:31 PM
nostatic's Avatar
I know they can be bench tested, but I don't know the details. I can say that even a clean bench test doesn't mean that it is totally healthy...but it should be good for a work/no work answer.
Old 12-20-2003, 05:37 PM
Re: Bench-testing alternator
diodes are impact sensitive.. even a car crash may destroy a diode. I assume things haven't changed much in 30yrs concerning diodes. A quick diode check involved an ohm meter connected to alt output and the alt ground with wires disconnected from the car. I think the routine was less than 1k ohms for everything to be OK.. Sorry I haven't done the routine in years.. but any shop guy will know.....
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-20-2003, 06:08 PM
Lorenfb's Avatar
You really can't check the diodes that way. They are all (three at time)
connected basically in parallel because of the windings. Two of the
three could be bad and the resistance check would be O.K. The unit
really needs to be turned using a motor or a drill.
The D+ and B+ outputs need to be checked separately. Each is connected
to the DF and excited using a test light connected to 12 volts. Once
the alt. reaches about 600 rpms, the testlight will go out indicating
that all diodes are O.K. for that output (D+ or B+). If the light glows,
then a diode/diodes is/are bad.
Have Fun
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-20-2003, 06:26 PM
To check diodes, you have to unsolder them to test them individually for one-way continuity.
A "bench test" at an electrical shop where they physically spin the alternator is probably a better suggestion.
Sherwood
http://members.rennlist.org/911pcars
Old 12-21-2003, 03:16 PM
KNS KNS is online now
Thanks guys, I'll find a proper shop.
Kurt
Old 03-22-2010, 07:43 PM
Whoops! Responded to a seven year old thread.
Kurt
Old 03-22-2010, 07:59 PM
Senior Advisor
James Brown's Avatar
Take it to any shucks or napa and the'll check it out for free.
08 Cayenne Turbo
Old 03-22-2010, 11:28 PM
Senior Advisor
Crap, me too!!
08 Cayenne Turbo
Old 03-22-2010, 11:33 PM
AutoBahned
RWebb's Avatar
never hurts to bump an informative thread
Old 03-23-2010, 01:01 PM
Senior Advisor
Yes it will be asked again soon
08 Cayenne Turbo
Old 03-23-2010, 06:56 PM
shbop's Avatar
..and a 944 pulley fits right on. jic
Jon
Old 03-23-2010, 07:54 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by 911pcars View Post
to check diodes, you have to unsolder them to test them individually for one-way continuity.
Sherwood
Index
+1
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-23-2010, 10:36 PM
