LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Matt-Man's Avatar
rds356, sent you an e-mail.
Matt
'73 911 Targa / 2.7 RS spec
Old 03-12-2004, 08:11 PM
Craig Roche's Avatar
Hey Matt,
Thanks for the info here! I'd like to see some close up photos of the finished hinges. Nice job!
Craig
1984 911 Targa
Old 03-19-2004, 04:42 AM
Matt-Man's Avatar
Thanks Chris. I haven't had time to finish my own hinges yet, but here is a picture of the set I just sent out Thursday that belong to rds356...
Matt
Old 03-19-2004, 02:07 PM
Matt,
When using 2 hood shocks on one side you may find that it causes the deck lid to not lay perfectly flat. I think a mod where there was a shock on each side would be ideal.
Bill
Old 03-19-2004, 02:33 PM
unimog's Avatar
To freshen up the related engine lid info, (it has been covered in other threads, but since this is the newest one on the conversion, here goes)
AutoLoc controller
http://www.autoloc.com/detail.lasso?itemid=WC1000
WC 1000 - $39.95
I got mine from "rx4speed_com" on eBay for $24.99, 'buy it now' price (great seller)
C2 Deck lid
Again I got mine off eBay. The seller did a 'buy it now' for me at $299.99 with $50.00 shipping. Going price seems to be $300-$600.
993 Pictrogram switch
I found a used one at Dunkels Bros swap meet. On the internet, and "WTB" on Pelican I had no luck. If ordered from a Porsche dealer you must include the color code even though they are only available in black, so part number is 993.613.203.00.01C (01C is the color code). List price is $47.00 with a 5 day lead time. Otherwise the power window switches are easy to find used, and MUCH cheaper.
Of course "The website" with the conversion information and wiring diagrams.
http://66.34.72.138/howto/c2-lid/index.html
Matt had a good idea to wire the spoiler so it 'power-off' stows... so when you park, it is always in the down position. I'd like to wire the spoiler so it will deploy in any gear higher then 1st, and stow in first gear (poorman's speed switch), in addition to the manual switch.
'04 BMW R1100S BCR
'01 Audi TT RS
gone but not forgotten:
'87 911 Carrera '59 356 Coupe
'66 912 Speedster '99 996 Ducati
Old 03-19-2004, 03:05 PM
Matt-Man's Avatar
Thanks for posting the info Mark! Bill, thanks for the input. I will come up with a bracket for each side...
Matt
Old 03-20-2004, 06:06 PM
Matt-
I just picked up a used set of hinges on ebay that I would like to use to fit a C2 decklid to my 76 targa. Can you help me out with the hinges?
Thanks,
Jon
Old 03-20-2004, 06:13 PM
Matt-Man's Avatar
Of course!
Sent a PM.
Matt
Old 03-20-2004, 08:43 PM
I love 964 decklid for my carrera euro 86.
I have A/C in my car.
It is posible for my car with A/C?
It´s posible fixed cooler independient of decklid with other hinges?
Please please I have more problems for look for about this cuestion.
The idiom is a very problem for me.I want pparticipation more in this forum but the enghish is my big problem. I´m sorry.
regards for all
Luis
Old 03-21-2004, 03:49 AM
Matts Hinges
Matts hinge modification is over the top. It looks great.
Very strong indeed. Also a great value.
I detect a new side business.
Will post pics as soon as the deck lid is painted and mounted.
Regards Rich
Old 03-21-2004, 03:56 AM
Matt-Man's Avatar
Luis, you will have to relocate your AC condenser from the deck lid to a remote location like the front fender area. I think a company called Kuel? has a kit for that. Hey, I'm sure we can work around that pesky lanquage thing... Any one else know more on the AC issue for Luis?
Rich, glad you got your hinges back OK! Let me know if you have any problems or suggestions...
Too all, while you were all sleeping like Babes last night I worked out a prototype strut/shock mount for the right side that will duplicate the geometry on the left side. Will require bolting or spot welding the body half of the mount to the underside of the package tray, just like the factory. Let me know what you think.
Add $25.00 for the shock mount option.
Thanks so much, Matt
Old 03-21-2004, 03:34 PM
Matt-Man's Avatar
Ray 911s, got your hinges today, DHL/Airborne sucks! (at least in my area) Two packages within a week from them and they... too long of a story. Anyway, I will get them out ASAP!
Matt
Old 03-26-2004, 07:51 AM
Ray 911s's Avatar
Second set of "cores" are on the way, Matt. I have another set of extras here, too. If anyone else needs spare hinges for the conversion, check with Jerry
I have a set of spare 964 hinges if anyone wants to try to fab a solution using the new style hinge. If the magic number is 1.125" then a longer hinge pin and simple added bracket (like the extra shock mount bracket) should do the trick.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 03-28-2004, 09:17 AM
Matt-Man's Avatar
Thanks Ray, your hinges are done and will go out ASAP! Let me know of any problems or suggestions...
Matt
Old 03-28-2004, 06:33 PM
Matt-Man's Avatar
Update on installing the hinge shock mount for the right side; if you look in the area under the package shelf about where the mount should go, you will see a flat mounting pad just like the left side has. My mount will fit there perfectly like stock and can be spot welded or drilled and fastened with sheet metal screws or better yet small bolts & nuts. It is boxed in that area, so no fear of a short screw going through your package shelf. If you remove the package shelf cover and soundproof from inside the car you will see access in that area to install a nut.
I can also make this modification to stock hinges for people who add a wing but don't want to use a double shock kit. Tell your friends!
Thanks, Matt
Old 03-29-2004, 07:49 PM
Matt-Man's Avatar
Thanks Steve, your hinges are on the way!!
Matt
Old 04-16-2004, 02:16 PM
SilverPoly's Avatar
Wow Matt,
That was fast! Thanks for the quick turnaround. Now I can ditch those washers I have on my current set up.
Old 04-16-2004, 02:28 PM
Matt-Man's Avatar
Thanks Mark, your hinges are going out today, UPS. I will e-mail you when I get a tracking number. And thanks for the switch!
Matt
Old 04-19-2004, 02:34 PM
unimog's Avatar
Matt,
The hinges arrived about 5 minutes ago, only one word- WOW!
If anyone is thinking about this mod, Matt is the way to go. Not only do these hinges look like they came straight from Stuttgart, but Matt even includes 'Tips for installing your hinges and adjusting your deck lid'.
Matt you are da Man!
'04 BMW R1100S BCR
'01 Audi TT RS
Old 04-22-2004, 05:59 PM
Matt-Man's Avatar
Thanks Mark! Glad you like the hinges and have a good time on your Fun Run!
Matt
Old 04-23-2004, 07:26 AM
