Fabricator
Yes, I thought the description use to read, fits '65 - '89, '65 - '68 requires slight body modification. The inner flange needs to be ground about 3/16 on the top where the lights are and the same on the inside vertical edge.
FYI guys- I have a set of Rays LED lights. They are great. The fiberglass work is top notch.
The weight of a complete stock 911 rear tail light assembly is 3 pounds 9 oz. (7 pounds 2 oz for the pair) I do not know how people say these things are over 5 pounds each. These are off my 1969. Rays LED light assembly weighs a tad over 14 oz. each (1 pound 12 oz for the pair painted) Total weight savings for the rear of the car - 5 pounds, 6 oz. (I think my math is right ![]() All weights taken on the same digital scale.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 03-06-2005 at 04:00 PM.. |
Here is a picture. I have to do some final buffing/rubbing but they looks great.
Mine are Red/Red because we do not use them turnsignals when racing ![]() Both lights on each side light up... Nice and bright. I need to return a "Brake Check" favor to a fellow racer. I thought these would be a great addition to help. ![]()
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
Air Medal or two
Now thats eye candy.....Looking good!!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
This week I'm installing my led lamps with reverse and I'm having a bit of trouble with the wiring. Ray offered to help but he is traveling this week and mentioned communication may be slow. Please help!
This is what I think I know about the wiring in my '71: black/yellow stripe - brake light black/white stripe - turn signal grey/red stripe - running light gray/brown stripe - backup light brown - ground and the red LED lamps: white - ground black - turn/stop red - tail the white LED lamp: black - reverse signal white - ground The backup lights work. No problem there. The problem is the brake/running light/turn signal red LED lamp. The LED lamp has three wires. My OE wiring uses four wires. I need to know the proper way of connecting the 4 OE wires to the 3 wires on the back of the LED lamp. The turn signal seems to be working with the running lights off but when I turn on the running lights the LED lamp does nothing. Currently I have the wiring connected like this: red - grey/red stripe black - black/yellow stripe + black/white stripe white - brown for the backup lights: black - gray/brown stripe white - brown The red and white LED lamps both share the same ground. Is my current wiring correct? Thanks for the help, -Kaefer |
Here is a close up of the red and amber lamps.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
likes to left foot brake.
In the fine print it mentions these are no brighter than an incandescent bulb, and that the LED conversion is just for long life. I thought the reason for going LED was to have a brighter light? Also in the fine print some issues about matching the lens color to the LED color? Has anyone had success with these replacements led bulbs? Which ones are best suited for 911 tail lights and turn signals? |
Hello from the airport terminal!
Kaefer's set up is using a single lamp on each side for all functions Stop/Turn/Tail. For visualization, the photo from Shawn above uses the red lamp for Stop/Tail and the amber lamp for Turn functions. Kaefer's kit substitutes a white lamp for reverse in the location of Shawn's amber turn lamp. I have one other application similar to Kaefer's, but the wiring turns out to have been non-standard. In theory, a single S/T/T lamp should operate as "on" for tail, "bright" for stop, and alternating on/bright for turn. The standard Porsche harness and flasher doesn't resolve the conflict between between "bright" for stop and turn, so we're working on a patch now.
1977 911S 1973 Alfa Romeo GT Veloce 1997 Lotus Turbo Esprit V8 2016 AMG C63S |
"I thought the reason for going LED was to have a brighter light?"
Many aftermarket LED conversion lights are not DOT legal. I don't know whether it has to do with ultimate brightness and/or the off-axis light levels. Many new cars use LED stop/tail lamp assemblies. These probably meet specs by the sheer number of LEDs in the housing and the size of the lamp assembly. One advantage of LEDs is the faster ON response time compared with incandescent bulbs. At highway speeds, the difference can equate to enough distance to prevent a collision. Late 911s that use a pressure switch in the master cylinder typically require higher brake pedal effort to close the brake light circuit. The R-type rear TL housings I've seen don't produce a lot of light, especially during the day (and that's with incandescent bulbs). I would suggest adding an LED light bar (3rd brake light) in the rear window to keep the semi trucks off the rear end (see archives for a $20 solution). As far as an aftermarket LED stop/tail lamp, I'd shop for the largest, multiple LED bulb assembly that fits inside the housing/lens. If the application is a track-only car, one could reduce some add'l weight by replacing the regular taillight harness with one using lighter gauge wire. The amount of current required of LEDs is miniscule compared with incandescent bulbs. Kaefer, Just a WAG. If your current wiring connections are the same as the factory setup, perhaps it might have to do with reduced current flow through the system that affects the existing turn signal flasher (relay). Mechanical relays need a minimum threshold current flow to work and LED current requirements are low. JT's LED link shows a device to provide the correct load in the circuit. Or you could use an electronic flasher. However, since the factory uses a 4 prong relay and most flashers are 3-prong, I haven't yet worked out the elec. connections to make this conversion work (it might be easy or not as). Sherwood Last edited by 911pcars; 03-08-2005 at 09:21 AM.. |
If I had a pair of amber lamps I might be able to hack apart the white and amber lamps and make a white/amber combo lamp out of the two seperate lamps. -Kaefer |
I'm going to try and hold off and See what Ray comes up with for a patch. -Kaefer |
Ray,
Are there 2 different levels of brightness with the 3 wire reds? I hooked both the red and black wires from all the lamps to the brake light wire. When I tried, they did not get brighter than the regular brake brightness (From just using a single wire for brakes). There should be two levels of brightness...correct? Is this "patch" going to resolve this?
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 03-08-2005 at 09:43 AM.. |
With the 3-wire lamp, the black & ground circuit turns the lights in "on" mode and the red & ground circuit lights the "bright" mode. (check your instruction sheet to make sure my memory is OK here)
Chad, your set up uses four three-wire lamps. For lights you should use the black and for brakes you should use the red. Turning on the tail lights will light all four lamps in "on" mode. When braking all four lights will increase to the "bright" mode. You should never connect both the red and black wires to the same feed. The circuit board won't suffer, but as you observed, you'll confuse the wiring fault (lamp out) circuit in the car. Scott, you can't split the lens to get two colors. In order to get DOT compliant for both brightness and 180 degree visibility the lamps use two LEDs, both on the same circuit. The internal circuit board controls switching of the lamps depending on which lead is "hot" from the wiring harness. Use of a single S/T/T lamp will require a circuit or patch to allow the turn function to dominate the stop function when both are activated. I discovered that the test car utilized a four-pole turn signal flasher so this issue didn't surface. The fix should be pretty basic - the intention will be to modify the turn signal from "bright vs off" to "bright vs on." To get running now, Scott, disconnect the black/white Porsche wire from the black wire on the new lamps. While I'm travelling I don't have the installation instructions with me. I assume from your note above that the instructions indicate that black is for stop/tail? If so, then by disconnecting the blac/white from the black and making sure that the grey/red is attached to the red, you should have reverse lamps, tail lamps (running lights), and brake lamps operable. Sorry, I'm shooting from memory while I'm on the road.
Ray,
As per the instructions that came with the lamps: The red LED lamps: white - ground black - turn/stop red - tail The white LED lamp: black - reverse signal white - ground My factory wiring: black/yellow stripe - brake light black/white stripe - turn signal grey/red stripe - running light gray/brown stripe - backup light brown - ground Here's is the way the wiring is currently connected: red - grey/red stripe black - black/yellow stripe + black/white stripe white - brown From the post above it looks like if I snip the black/white stripe wire then I'll be ok until the patch is out? Will I be receiving the patch when it's available? Thanks for the update, -Kaefer Edit: I won't be ok by snipping the black/white stripe wire. That's my turn signal wire. With the crazy drivers around here I don't want to get rear-ended or ticketed because of not signaling for a turn. Arrgghhh.... Last edited by PcarPhil; 03-08-2005 at 11:42 AM.. |
Ray,
I sent you a PM about getting these gor my car. Hope to hear from you soon. Have a good trip. Vintage 911 Racer.
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
Ray,
also tried a PM, but not sure if your around. I'm also interested in a set for my 930. Shoot me an email at vlocci@rcn.com when you get a chance. I'll wait to hear from you before pulling the trigger on a AR concepts set. Thanks, Vin |
Hi, gang. Where I am the wireless broadband is spotty, but the steaks are good. I'll be back in Chi-town soon. In the meantime, while I have a pretty good signal I will get to the PMs.
Hmmm. I don't have any new PMS, guys. I'll try to email you directly.
Mark - I'm unsure how to reach you. Tried PM but it must not be working.
Thread Tools | |
Rate This Thread | |
