80SC widebody, 3.6VRAM with 915, full Griffiths AC set up
Looks great.
This thread is killing me. We started my 3.6 swap Wednesday, but when installing the LSD we made the decision to do a bit of work on the transmission which we won’t get back until Tuesday. ![]() ![]()
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
I'd highly recommend using a 3.3 console, regular 911 or RSR type 911 cross bar and Sheriden 3.6 conversion f/g to replace the tin. You do need to use a single or double sheave crank pully as well. W/ the 3.2 parrts the engine and exhaust sit exactly as in any other 911.
I have a spare RSR crossmember sitting in my garage and we have the single pulley conversion waiting installation once we get the front and aft pulley adapter. Timmons told me the RSR crossmember wouldn't work when I ordered the kit from him. Do you think this exhaust will have clearance issues? https://werksperformance.com/products/copy-of-porsche-993-carrera-rsr-header-muffler-kit-with-heat-dual-inlet-outlet-muffler-copy-of-993-rsrwh I'm also starting to have concerns regarding the 915 being able to handle 285-300 rwhp despite us fixing any issues with the transmission. I'm not going to hammer on it, but with and OS Giken LSD and rebuilt 915 it should be fine for several years without service...? What are your thoughts Bill?
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C Last edited by Ryan_Cunningham; 07-19-2025 at 11:05 AM.. |
On the subject of engine mounts, notice that the one in Bill's picture is reinforced at the ends. This is a great idea...those things twist quite a bit.
For transmission durability, I guess it depends how you treat it. I too heard people cautioning me about the 915 but I haven't had an issue nor do I know anyone with a 3.6L that has grenaded their 915. I did go with an '84 euro 915 (not my stock magnesium cased one) and I didn't add an LSD hoping to stress the transmission a little less, maybe having a little wheelspin here or there on one wheel. 911s get such great traction anyhow and I don't track this car, so the lack of LSD is hardly noticeable.
- '72 911T - '81 911SC Euro |
the 3.2 parts w/ Sheriden f/g tin replacement fits like a glove and returns the engine to it's usual position That exhaust looks exactly like the one I bought from Fabspeed, and I do mean exactly. If so it's great, best I've ever heard including the ones I've used on my 993. Only nit is that the tips are a little weal, appearance wise
1975 911S steel wide body, front fenders 1” wider each than 930 fenders, 915 gear box, 1993 964 3.6, Rothsport headers with GT3 muffler a-la Guntherwerks….. just finishing rust repair and paint after driving her as a black and white rat rod for 10 years. Build thread coming soon???
how it started in 2016... How it was going (DRT2022).... ![]() ![]() Almost back on the road now.... ![]() ![]()
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Love the blue finish & chrome trim. Good job!!
Patrick
912E-3.oh |
Thank you kind sir.
Instagram: @TuitTech |
Bill,
I have a timmons'/IG style 3.6VR swap in an '87. It is freaking tight on the top. Have you fit a 3.6 varioram with the 3.3 console, 3.2 bar, and sheridan tin? I'm not actually sure the engine could go up another inch with the ICV already pressed against the insulation. I know you're familiar and will echo that if you do nothing, your exhaust will be lower than normal. I scrape when driving hard and have a passenger in the car. I'm pretty low though. Another observation: There is some slight angularity at the transmission mount, but it's in the opposite direction you'd expect. It is tilted with the forward end down, indicating the engine is actually higher than the trans... I'll see if I can snap a pictures of this. Maybe my memory is off because this would be unusual. I'm fascinated by this swap now. It feels like it's not quite fully understood. PS: Not sure if photo is working as imgur is blocked at work. The little spouts are header dumps. One is unfortunately aimed a little downward. Last edited by AlBackus36; 07-25-2025 at 05:05 AM.. |
this is how my exhaust sits with my Timmons VRAM set up . It is tucked in nicely, it is a tight fit at the top of the VRAM intake though.
Thanks for the extra pics, Chuck.
I want to clarify the car is more than drivable. Ryan, don't think it won't be usable. I drive the car hard and it doesn't get in the way. If I have someone in shotgun I have to be extra careful over speed bumps or driveways. That's mostly it. |
How cool would it be to have one of these in a G Bobby?
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Good, I just didn't want to spook you away from your current path. There are hundreds of cars out there that have been done with the 3.6 console, etc.
I'm convinced the Varioram guys can't go higher, but would love to be proved wrong so I can raise my exhaust ![]() |
You'll either need to make room at the top or fab custom I/O pipes at the bottom
Take your pick
First wont you need to hit the lottery? I know a Rothsport 3.6 that makes 100HP/liter is at least $40k....plus your running engine. Byron's engine....double that for normal people? I'm out. LOL
Any color is fine as long as it’s black/black.
![]() Good to see so many fellow nutjobs who have spent a lifetime and small (sometimes not so small) fortune putting together their own personal versions of pure 3.6L German automotive bliss. Has been a fun and sometimes challenging 12 years for me. But this one is finally a masterpiece IMHO. Is the finished product everything I’d hoped it would be…yes. Would I do it again….no. My advice to anyone about to start down this path: if you’re not a mechanic and will be outsourcing the work, just buy a completed project and pay the premium for a properly sorted example. 75 911S Steel 930 fenders 5spd 915 transmission w/ wavetrack LSD 93 964 3.6L motor with Rasant Products GT3 intake w/ stock internals Motec engine management REVV short shifter Raised shift tunnel by Rebel Racing North Hollywood Speedo gauges with LED lighting Getty Design clear carbon hood Rennline carbon hood and decklid 356 style struts Fikse Fuchs (like the first Singer models) 17x9/11 Nitto 315/235 Sport comfort seats refinished in perforated leather Roll cage (ready for the track but never been to the track) Fiberglass rear early Turbo decklid Rebel Racing brembo adapters for big red brake kit from 996 Rebel racing adapters for Bilstein coil overs Rebel Racing 917 style aluminum accelerator pedal Rebel Racing semi solid engine mounts Custom suede headliner Leather covered RS style door cards and all dash parts New red seat belts Customs keys by Formawerx Cibie rally lights Bosch fog lights LED bulbs in the H4 headlights. Rasant Products rear tail lights (LED), Rasant Products brushed aluminum dash Stereo delete Carbon fiber RS style heat duct Momo 6c prototipo steering wheel Billy Boat exhaust with heat exchangers A/C delete Windshield wiper fluid pump delete but wipers work Wet weight 2499 pounds RWHP 301 on the dyno ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by plexiform; 07-23-2025 at 07:25 PM.. |
