Throw it on the ground!
Forgot to ground the violet and violet/black fused lines......works like charm now!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 02-03-2007, 06:11 PM
Bill, I was able to reprogram the system to cancel the auto lock ignition function.
I decided that I didn't want the valet "programming" button or the red led indicator light mounted anywhere on the dash so I located them in the trunk near the main unit and cut out a small carpet square for access.
Mark
1987 911 Coupe
Old 02-04-2007, 05:42 AM
wcc wcc is offline
wcc's Avatar
mthomas58 - That's cool that it works. Looks like you did a good job installing it too. I think I'd mount it like you did, in the trunk. Now I'm sold on this. I've added this project to the list for this spring.
Bill
997.2
Old 02-05-2007, 05:10 AM
Great install, Mthomas58. I need to rework mine to look more like yours! What did you do with the huge bird's nest of wires? Also, how is your range? Magic930 said he was able to use his remotes from about 60 feet, but my range is really short, closer to 10 ft. I have the antenna wire mounted above the carpet. Maybe my batteries are old?
Tom
88 Targa - Mostly stock except cat bypass, SW Chip.
06 Audi A4 2.0t Quattro
02 Saab 9-3, 06 VW Passat, 06 Chevy Cobalt
Old 02-06-2007, 05:34 AM
Didn't really have a huge birds nest of wires. I cut off the unused wires about a foot from the big connecter. The excess valet and led wires were wound and then zip tied to the board panel (two holes drilled through - zip tie out and back through - holds the wired tightly against the back of the panel) Did the same with the control unit in addition to the double faced foam tape so it would not come loose. All of the other wires to the fues panel were just long enough to get there (routed around the back side of the master brake cylinder.
My range is closer to yours at about 10 ft. Tried yesterday from my coat pocket and it didn't work. Oh well......range really isn't all that important (is it?).
Mark
1987 911 Coupe
Old 02-06-2007, 05:52 AM
Found a great solution for the limited range issue on the Black Widow cross-referenced here:
http://forums.pelicanparts.com/porsche-911-technical-forum/357450-upgrade-available-black-widow-keyless-entry-systems.html#post3393194
Solution is an extended range antenna available from Black Widow. Part # ERM2. Open up unit, unplug old antenna board (connecter is hot glued) plug new antenna lead and route through bulkhead wall behind radio and temporarily mounted on antenna on windshild pillar. Will test range from several locations before settling on a permanent location. Range with this antenna at this location was an amazing 475 feet!!! Cost $18.00
Mark
1987 911 Coupe
Old 07-23-2007, 05:18 PM
timeless beauty
rcaradimos's Avatar
any more information on this?
Thanks in advance
Bob
Old 07-25-2007, 07:42 PM
Thanks in advance
Bob
Bob, addl details in the attached link to a seperate thread on the extended range antenna installation. It's a great improvement.
Upgrade available for Black Widow Keyless Entry Systems
Mark
1987 911 Coupe
Old 07-25-2007, 08:03 PM
timeless beauty
rcaradimos's Avatar
great video, looking @ an audiovox to install at the local auto zone 49.$ just want to make this as simple as possible
Bob
Old 07-26-2007, 03:35 PM
timeless beauty
rcaradimos's Avatar
Mark, did you use the diodes, or some other method for the parking lights?
Old 07-26-2007, 08:24 PM
I did use the diodes exactly as those pictured earlier in the thread (important: grey stripe towards the fuse panel). Radio Shack stocks them.
Mark
1987 911 Coupe
Old 07-27-2007, 05:00 AM
timeless beauty
rcaradimos's Avatar
finished! And it locks and unlocks when the key is turned in the ignition, center console light comes on and off too.
Might be because i connected the switched power wire to the indicator fuse terminal #11 that seems to be the only power source that has power in the ON,START,RUN position and NO power at ACCESSORY or OFF (as stated in the manual) for this feature to work.
Also programed the unit "on" for the power switched on lock off unlock feature.
Thanks for the post great upgrade
Bob
Old 07-27-2007, 12:02 PM
timeless beauty
rcaradimos's Avatar
The green arrows are where i connected into the fuse box, i also did the diode setup, the wires that go to the brown/green and brown/blue wires i just exposed some wire from the unit and folded up against the isolation and back stabbed them in the round plug
Hope this helps someone in the future
Bob
Old 07-27-2007, 12:39 PM
The original unit that was listed in this thread has been sold out for months. Has anyone found and installed one that is comparable. I am looking for a unit that basically provides keyless entry for the 964. My key will not lock the drivers door and I am thinking this will kill several birds so to speak.
Thanks,
Kevin
Kevin
'79 Coupe
Old 07-30-2007, 06:50 AM
SCWDP911's Avatar
Awesome idea and writeup guys. Has anyone done this on a car with no power door locks? My 83 cab does not seem to have them. Is it a more pain than it is worth job? For Z$30, it would be a ncie thing to have, but still not necessary...
Shane
- 1984 928S
Old 07-30-2007, 07:00 AM
Thanks,
Kevin
Etronics sells the BWS1 for $50 that comes with the extended range antenna.
http://www.etronics.com/product.asp?stk_code=blabws1
Mark
1987 911 Coupe
Old 07-30-2007, 08:25 AM
timeless beauty
rcaradimos's Avatar
You need power locks or you will have to add allot of stuff in the door panels, the cost will go up and simplicity would become difficult. A job for a audio/alarm shop in your case i think.
Old 07-31-2007, 03:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Great Thread Guys, Thanks to Wickd89 for the the re-direct
'85 Carrera Targa
PCA/POC
Old 11-12-2007, 09:15 PM
DRACO A5OG's Avatar
Question An Oldy but a Goody Thread DIY Keyless Entry
OK Gents,
Just got my BW854
Preped and tagged all the wires for install. I chose to place my LED in the cab where the Cab Temperature Sensor would have been and place the Valet/Program button in the trunk.
Question I have is the BW unit's Red Wire goes to rcaradimos' #11 or manual's #8 then the Yellow Wire goes to rcaradimos' clock terminal or manual's #1 both in Fuse Panel #1? I know the clock is constant and so is the Hazard Light Indicators, I suspect red goes to #8 because of the 16 amp fuse and the yellow goes to the 5 amp fuse. Need confirmation please.
I chose rcaradimos' method so I won't have the ignition auto lock and not unlock issue.
TIA
'85 Carrera Targa
PCA/POC
Old 11-26-2007, 11:58 PM
jonbot's Avatar
I just ordered one of these universal kits off flea-bay for just this purpose, if anyone's interested, I can document the install in a thread.
Jon
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 11-27-2007, 12:16 AM
