Does my SC really have a valet key?
When I purchased my 80 sc a year and a half ago it came with two keys, one that worked everything and one that only worked the ignition and doors and it did not work the glove box or trunk lock.
Well, my wife lost her keys along with the good Porsche key and all I have left is the "valet" key. The glove box is locked with my radio faceplate stuck in it so I am currently radio-less.
Questions:
Do I really have a valet key or did the last key maker just suck?
How do I get in my glove box?
How do I get a key to open the glove box?
Old 06-28-2007, 04:19 PM
The valet key should have a red plastic end. The full-service key has black plastic. Beyond that, I'll let someone else answer the important question about getting into the glove box.
Old 06-28-2007, 04:59 PM
They are both black. The lost one had the porsche logo and light built in and the one I have left has a nearly rectangle black top.
Old 06-28-2007, 05:05 PM
RETIRED
Joe Bob's Avatar
Do you have AAA? They will pay/reimburse you for the locksmith for the labor and key.....
2012 ML350 3.0 Turbo Diesel
Old 06-28-2007, 05:41 PM
No AAA....
Old 06-28-2007, 05:43 PM
Lost Key Replacement......
Therotman,
If you need to get a duplicate of the original key, my suggestion is go visit the nearest Porsche dealership and order one. You will need some documentation like registration and ID for them to make or order the key/s for you. If the key tumbler has been altered from original, you might be in trouble. Good luck....
Tony
Old 06-28-2007, 05:54 PM
RETIRED
Joe Bob's Avatar
Originally posted by therotman
No AAA....
Pull a door lock and take it to the locksmith....
Old 06-28-2007, 06:09 PM
HarryD's Avatar
The button is your friend. Use the terms valet key master. I did and found this:
Need pic of Valet and Main key
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-28-2007, 09:59 PM
Glove box & trunk locks
Hope you don't mind a query from England!
When I bought my SC Targa (1980) I got three keys with it. Two are keys with a plastic top and a light (not working of course), the other is a plain metal key.
All appear to be the same in that they operate the ignition and both doors. But none of them operate the Glove box lock or the Trunk lock (fortunately, both of these are unlocked!).
I would like to be able to lock these, quite important I think in a Targa.
Any advice?
Old 05-19-2012, 07:54 AM
QSYSOPR Extrordinaire
Last year, I got tired of the sloppy key action in the ignition, and ordered a new one through the local dealer for my 85 ROW. Using that key as my master, and made a copy.
Dealer mentioned that 85 was about as far back as they go these days. But worth a try.
Old 05-19-2012, 08:57 AM
naparsei's Avatar
Just a side note - if you are in the US, I would seriously consider getting AAA. It's cheap, you can add (additional $$$) long range towing, and it's practically, IMO, a must have for someone with a 32 year old car.
edit - the discounts alone (usually best rate available) easily cover the cost if you travel at all.
'74 Euro Carrera * '64 356SC Coupe
Old 05-19-2012, 09:09 AM
Porchcar guy's Avatar
+- on AAA PLUS -100 mile tow -4 times a year - tire change - lock help - I have used mine each year at least one - around a $100 annually - great deal !!
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 05-19-2012, 09:26 AM
If you need to have keys made, it's a simple thing to pull a door handle off and to also remove the lock from the glovebox. A locksmith (or anybody, really) can remove the lock cylinders and disassemble them. You can then measure the parts and come up with the info you need to cut a key.
If you have a key that doesn't work the glovebox (or front trunk lid lock, on cars so equipped) you have a valet key. If it's not cut on an original valet key blank, then it's a copied key, not an original.
JR
Old 05-19-2012, 12:17 PM
I'm looking at my '80SC keys, valet and master. They both have exactly the same profile ground into the keys! The difference is the slots cut along the key blank from manufacture, and the valet key should be red (even though yours is black). You need to go to a key maker and have him copy your valet key profile onto a master key blank. Just compare your valet key to the blanks, and the master key slots will look quite different. Good luck!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-19-2012, 01:42 PM
OK, here's a pic, the black is the master. Just find a blank with the same appearance, and cut it to your valet profile, and you're good to go!!!
Old 05-19-2012, 01:54 PM
All my three keys look like the Master above .. but none of them lock the bonnet (trunk) or glove box. I think I will have to take the advice of javadog and disassemble the lock, perhaps the lock has just stuck in the open position through lack of use?
Unfortunately, the AAA is not an option!
Thank you all for your advice, I will report back.
Old 06-05-2012, 01:03 AM
Hi a query from Holland, there is an item in the tech info center about this issue.
Pelican Technical Article: Rekeying Porsche Locks - 911 (1965-89) - 930 Turbo (1975-89)
Good Luck!
Regards,
Patrick
Old 06-05-2012, 05:45 AM
I have taken the Glove Box lock apart, adjusted the tumbler pins, and the lock now works.
Thank you all for your help.
Just one more thing .. I want to do the same to the boot (trunk) lock, does anybody know how to take the lock out of the housing?
Old 06-23-2012, 02:24 PM
Information Junky
island911's Avatar
Seriously guys? . .. no one followed this PERFECT link?
Need pic of Valet and Main key - Pelican Parts Technical BBS
Where Warren Hall nailed this...
Originally Posted by Early_S_Man View Post
The valet key has an extra long scallop cut/groove, or it is on opposite face from master key? 'Cut' pattern is identical, for sure, i.e., you can make a new master key from a spare valet key [or vice-versa] if it comes to the worst-case scenario!
Old 06-23-2012, 02:46 PM
HarryD's Avatar
Why yes. I did it years ago. You need to pull out the handle to reveal a tiny set screw. You loosen the set screw and you can then remove the cylinder. My story here: Removing Trunk Release for a Targa
Harry
2020 MB E350 4Matic
Old 06-23-2012, 05:58 PM
