Throw it on the ground!
Where can I find a good thread(s) on a 3.2 to 3.4 rebuild?
Plagued by the 3 character search failure. Done numerous searchs and I've come up empty. Can anyone direct me to a good thread on a 3.2/3.4 rebuild using 98mm P&C's.
Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
A link to a link:
The 3.4 machine is almost done!!
'84 911, some sort of red color '05 Subaru WRX wagon |
I've been thinking of this myself, and will probably go with the Mahle Sport P&Cs, 964 cams, and stock Motronic with single spark plugs. It's a street machine, not a racer. You might get more luck trying Mahle or Mahle Sport on the bbs, such as Renn, or PCA.
MBruns for President
Jeff Alton's awesome 3.4,
Ralph's 3.2 to 3.5 - Part II Gnat was doing a 3.4 as well as synchroid Asphaltgambler was doing one too.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
specs on mine
3.4 mahle 9.8 to one jugs Single plug extrude hone intake 993ss cams (Dougherty Racing Cams) arp rod bolts Supertech Head Studs enlarged throttle body competition springs and retainers (EBS) (QSC) LN 1 3/4" SS Headers Dansk Dual in - Single out Steve Wong custom chip to pull it all together
My rebuild underway ....
3.4 Mahle 98mm P&Cs (Euro 10.3:1 CR) DC20 Cams SRP Valve Springs +3mm bored throttle body KEP Pressure Plate 930 sprung disc Scart pre-silencer DP Motorsport 1in1out main silencer Will have a live remap once run in SP EDIT - another thread here 3.2 to3.4
Shirish 1987 Carrera, Granite Green Last edited by sp_cs; 08-04-2008 at 02:49 PM.. |
maybe a little OT
Thoughts are that when this engine either burns out or I run across a super $ deAl, I'll instAll a 3.4. being how this car is pointedly built to travel x-country I'd want max torque at around 4.5k rpm. If there's a sacrifice above 6k rpm I don't care. One of the greatest things you can do with this car is cruise at 3.8-5k rpms in 5th for hours and hours with a 915 in the great west. Which leads me to wanting more torque when doing it. It's All about suspension, spoilers, tires, a strong tranny and 930 brakes. I need more power between 90-120 mph. It Also has to be operated with regular gas. I could get more "snap" out of my 2.7 with higher compression but then I can't go anywhere with it. I think I can 3.4 a 9.1:1 with regular gas and a twin plug. I don't want to push the envelope either. Reg gas is Already 10% Al nearly All over and it'll probably get worse. Head work could get interesting Also? anyway, a loose thought would give me something to think about.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks for all the great leads. Great threads - food for thought.
![]() What to do? What to do?
Enjoy! I sure did. Part 1 http://www.europeancarweb.com/projectcars/0503_ec_1988_porsche_carrera_engine_rebuild/index.html Part 2 http://www.europeancarweb.com/projectcars/0505ec_porsche_911_sc_carrera_machine_work/index.html Part 3 http://www.europeancarweb.com/projectcars/0507ec_porsche_911_sc_carrera_machine_work/index.html Part 4 http://www.europeancarweb.com/projectcars/0510_porsche_911_sc_carrera_engine_assembly/index.html Part 5 http://www.europeancarweb.com/projectcars/0601ec_porsche_911_sc_carrera_intake_exhaust/index.html Jeff Alton's 3.4L Rebuild Part 1 3.4 has begun! (part 1) Part 2 3.4 build part 2! Part 3 (who needs viagra!) The 3.4 machine is almost done!!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 08-07-2008 at 01:52 PM.. |
JeremyD, thanks for the leads. Done some more research and found the above on Ralph's rebuild if you have not seen it. IIRC ghnat is here in Atlanta.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 08-07-2008 at 01:53 PM.. |
