Engine Drop Ooops!
The first thing I should do is change my user ID to IDIOT. What is the possible damage I caused by letting the motor drop WITHOUT support? I undid the two rear support bolts w/o any support under the motor and "bam!", the motor dropped till it was about six inches off the floor. I quickly jacked it back up, hooked everything back together and she seems to drive and shift fine. It's a 3.2 with G50. Please tell me I didn't damage anything!!!!! (idiot!)
Old 11-10-2008, 03:54 PM
crustychief's Avatar
Whooops! I am not sure about the g-50 but the shift rod could have bent, I guess it shifts fine though? I am glad it didn't apparently wreck anything. Welcome to the board and post a pic of your car!
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 11-10-2008, 03:58 PM
Zeke's Avatar
For a 1st post, this seems odd. Whatever. Yes, there may be some collateral damage. Check all flexible connections to the motor including fuel lines, throttle cable, wiring, heater hoses, oil lines and more that I can't think of right now. All together, these things can hold a motor up for a minute or so. Maybe longer, but they can be stressed.
Old 11-10-2008, 04:02 PM
rnln's Avatar
I am sure there are many things more to check, someone can chime in, but I think the first thing to check is the shift rod and tranny mount bar.
Now do you feel a little shaky driving hard around with your engine hanging on 2 bolts? or 4 bolts for engine and tranny?
Fat butt 911, 1987
Old 11-10-2008, 04:03 PM
Wow - that was quick, four replies in under 10-minutes! Am I the only person on earth to have ever done this? Should I sell the Porsche b4 I cause more damage? What a loser. From what I've heard so far, the shift rod may be the main concern? If so, is that hard to fix/replace? Any other possible damage?
Old 11-10-2008, 04:19 PM
grateful user
don gilbert's Avatar
possibly brain damage
Old 11-10-2008, 04:23 PM
UnRegistered User
billybek's Avatar
I have read a couple of posts where guys haven't installed their mounts correctly and the motor dropped, and it sounded like they were moving at the time!
Good luck, welcome and post a picture of your ride!
Bill K.
Old 11-10-2008, 04:28 PM
You get this response 24/7 It is the best forum for our cars IMHO.
Old 11-10-2008, 04:30 PM
Free minder
Aurel's Avatar
I was going to mention the transmission mounts and shift rod, but others were faster. Now, if I may ask, what were you trying to achieve by unbolting the motor mounts? Did you really want to drop the motor?
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 11-10-2008, 04:39 PM
Slumlord
Porsche_monkey's Avatar
My guess is you got lucky and everything is fine. The shifter might be bent, but I would guess that the tranny mounts twisted and the engine jammed on the fan or some other part at the back end.
The engine requires a bit of manipulation to pull it out, I am hoping this worked in your favor.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 11-10-2008, 04:48 PM
Non Compos Mentis
There is an old thread: "Admit to you're stupidity". It goes on for several pages. You're not alone.
Old 11-10-2008, 04:52 PM
Friend of Warren
You aren't the first person to have admitted to this on this board. If it is shifting fine I doubt you even bent the shift rod. Check all your other connections, but I suspect everything is just fine.
Kurt V
Old 11-10-2008, 06:02 PM
you might have pulled a heater hose or 2 off where they attach to the chassis so you may have less or no heat.
if the rubber S hose from the oil tank to engine is 20 years old or more, it can have cracks that you can't see until too late and starts leaking.
also the thermal time switch wire terminals will pull off at a certain point, and the throttle linkage can be bent a little.
Old 11-10-2008, 06:16 PM
At the track = great day
ChkbookMechanic's Avatar
People make stupid mistakes.. luckily it is just a car and those can be fixed.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 11-10-2008, 06:28 PM
mca mca is offline
mca's Avatar
I was in the stupid club this weekend too. Didn't tighten my valve covers enough. When I hit the highway it looked like my entire car was on fire - oil POURING all over my SSIs. What an idiot.
Hope everything is ok - sounds like it is. I guess you are only stupid if you make the same mistake twice (or three times ).
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 11-10-2008, 07:19 PM
GaryR's Avatar
Send a message via ICQ to GaryR
That's what I was thinking also.. 1st post - "Hey. I just undid my two motor mount bolts and my motor fell out"... apparently just for the heck of it? Only six bolts hold the door on, just so you know..
Gary R.
Old 11-10-2008, 08:21 PM
DanS911's Avatar
That reminds me where is that stupid thread...........
Dan
'86 911 Targa Driver
'76 911 Targa 3.0 Track Toy
46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky)
Old 11-10-2008, 08:30 PM
Formerly known as Syzygy
Canada Kev's Avatar
Butterfingers...?
We all pull bonehead moves from time to time. I think the duration between them is key, though.
-kevin
Kevin
Old 11-10-2008, 09:26 PM
tharbert's Avatar
You will accrue bad karma until you post a picture. At that point, folks will start telling you it's not so bad. Check the soft connections and all will be well...
Old 11-10-2008, 09:35 PM
briancoates's Avatar
Hmmmm.......... did not realise they put 3.2's and G50's in Veedub's, sorry could not resist. Post a pic and stop the rot!
And I am curious as well, what were you trying to do when you removed those two bolts? very strange way to start a post.
Old 11-11-2008, 02:17 AM
