LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Air Cooled
Craig_D's Avatar
Hot damn!! Outstanding! I'm in Boulder Colorado and hope to see your creation in person some day soon!
Cheers,
- CraigD
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-28-2010, 10:53 PM
I love it!
There a 934.5 on ebay via Canepa Design with some great pictures including the bottom side.
Canepa Design - Photo Viewer
The water pump is driven off one of the cams and the turbo drains into the sump plate. Fun!
Old 03-29-2010, 08:00 AM
tadman's Avatar
vitaloni sebring mod
I was looking at how the different race 934's modified the vitaloni sebring mirrors. I'm sure they did it for all kind of reasons. With the mirrors right on the door as they were made to go there is not much adjustment. And the passenger side mirror is almost useless. I saw where some mirrors were lifted up some with plastic spacers and that helps. Looks like some were mounted with a mirror base like this lovely pink rig.
Well I found a base that I think workss ok to get the mirrors up a bit and get more visability and adjustment. Pegasus sells this spa mirror repair base that fits the 5mm hole. I made a small metal plate to give the plastic base of the mirror more support. Used the rubber that came with the vitaloni mirror to make a smaller gasket for the spa base. The main thing is drill a center hole in the door also incase you ever need to tighten the pivot bolt or adjust angle of the mirror, or you will have to remove mirror to do it.
Sheet metal backing plates for under mirror base.
To do one mirror: cut gasket, back plate, (2) 5mm bolts and loknuts for base (1) 5mm bolt and (2) loknuts for under mirror for support.
Small plate and base on the mirror.
Works for me , passenger side has much more visability..
Old 04-03-2010, 06:51 AM
tadman's Avatar
Front view w/mirrors on
Old 04-03-2010, 06:58 AM
Air Cooled
Craig_D's Avatar
Looking good!!!
'69 Honda CL350
Old 04-03-2010, 09:35 AM
juicersr's Avatar
Your mirrors look great. Helluva lot more functional than mine.
Any recent progress?
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 05-22-2010, 08:32 PM
tadman's Avatar
update
Not much progress, got 17" rims and R6 Hoosiers. Decided not enough choices in the 16" tires, 16" rims definitely look more correct but oh well.
The dash area is coming along, have a fiberglass top but thinking of putting the perlon on instead.
Mounted 25mm 935 style rear swaybar
Making up a pair of tabs to connect the front brake hardline to the flex because the stock tabs were removed when the struts were reworked.
Old 05-28-2010, 07:57 AM
Well thought out and way to nice for the track!
Old 05-28-2010, 08:15 AM
juicersr's Avatar
Looking good! Love all the 935 bits going in. Thanks for the info on the rennline tow hook BTW
Good decision on going with the 17's, lot more tire options and i see u have gotten a better offset with the new outer rim halves. I actually think the 17's look better on the 934 than the stock 16's ever did, as the 16s were always a compromise (width wise) from the start anyway due to FIA regulations at the time.
dzugautomobili.com
Old 05-28-2010, 10:36 AM
tadman's Avatar
Cut out the rear windshield and made up some straps out of aluminum to hold it in. Also cut out quarter windows and mounted naca ducts.
Old 06-29-2010, 01:16 PM
juicersr's Avatar
Very nice.
Is one of the NACAs feeding the turbo?
dzugautomobili.com
Old 06-30-2010, 06:03 AM
gumba's Avatar
I used the Vittoli convex mirror on the passenger side 935 mirror. I had to buy the whole assembly to get the mirror. Works great.
Who did the paint work.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 06-30-2010, 07:16 AM
tadman's Avatar
Harold the paint job was done by a guy out near Denver airport in Aurora CO.
Got the brakes working over the weekend and the car is officially a roller again.
Two more weeks and its over to Greg at Eurosport for the engine.
Damm getting spring fever already!!!!!
Old 09-22-2010, 03:30 PM
juicersr's Avatar
THE definition of bad azz bro.
Those 17's look the part. What size slicks are u running in the rear?
dzugautomobili.com
Old 09-22-2010, 04:40 PM
This is a great project. Keep it up man. It is inspiring my project!
Chris
If you want something bad enough you will find a way to achieve it. If not, you will simply find an excuse.
Old 09-22-2010, 05:31 PM
tadman's Avatar
rear tires
rear tires are 335 x35 x 17
Old 09-24-2010, 07:11 AM
spence88mph's Avatar
SOOOOOO tasteful, very impressed...
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 09-24-2010, 07:38 AM
Swapper and Ruiner
not_hans_stuck's Avatar
subscribed
Old 10-22-2010, 06:28 PM
Crotchety Old Bastard
RarlyL8's Avatar
Don't know how I missed this one, pretty nice!
Old 10-22-2010, 07:56 PM
Happiest when Tinkering
gsmith660's Avatar
Thats pure Porsche porn!
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 10-22-2010, 08:27 PM
