Noise with no idea
I took the Carrera out this evening and starting hearing this funny noise. I've heard it before but it's always gone away. Well this time it got bad and persisted. It's sounds like it's rotational. At first I thought maybe a wheel bearing or something to that effect. But it starts with acceleration, slowly then as speed increases the 'rotation' increases. But when I let off the accelerator it will stop. Also if I have the accelerator down and put in the clutch it stops. Any ideas?? Clutch going out?
![]() Thanks in advance for any thoughts.
O2 In Sully We Believe |
I think we will need more that that.
pitch source loudness nature: grinding, or flapping, or scraping
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
PITCH, not quite sure, certainly not a high pitch. SOURCE, kinda sounds like it's coming from the right rear of the car. LOUDNESS, Fairly loud when starting out then mellows to a constant drone NATURE, that's what I meant by rotational, certainly isn't a grinding noise nor flappling. maybe like clacking? Thanks
clutch or throwout bearing?
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Bumpity-bump
Throw it on the ground!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Ruby911
Does it increase with increase in wheel movement or motor movement (i.e. does it change with speed of the motor or speed of the car)?
Probably nothing a new set of Altons and a 3.6 won't cure ![]()
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Good thought Mark, it should be as it was changed late last year. But will check.
I do think the wheels would fix it! 3.6? na but will go faster.
CV Joints?
Never seen a clutch engagement quieten a CV issue....
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
What does it do when the car is in neutral, with and without the clutch engaged?
Fred 76 911s WB 3.0L 72 Int. Scout II 06 Mustang GT "Limping in the right direction is always faster than running the wrong way" |
What happens to the noise each shift? I think you might have inferred that the noise went away on each clutch action, but I wanted to make sure.
If that's the case, I'm going to take a WAG and say check your trans and motor mounts. |
Take a run, get up to speed, put it in neutral and that will tell you CV, wheel bearing, rotor issue engine or tranny mounts.....then turn while in neutral, thats when the wheel bearing, CV and mounts are stressed the most. Once you discount that, check the fan belt (with cold engine) to see if its loose. After start-up feel the top of the fan housing to check on an alternator bearing vibration. If all these are okay...continue to Plan B because........this is the extent of my knowledge. Best of luck.
I will tell you this.................a few weeks ago I was experiencing a crazy metallic noise in my left rear. It turned out that a small welded flange that connects the heat exchanger to the exhaust port (where muffler attaches) broke and the vibration caused a high pitched metallic sound!! Fixed in an instance. Bob |
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Thread Tools | |
Rate This Thread | |
