Noise with no idea
I took the Carrera out this evening and starting hearing this funny noise. I've heard it before but it's always gone away. Well this time it got bad and persisted. It's sounds like it's rotational. At first I thought maybe a wheel bearing or something to that effect. But it starts with acceleration, slowly then as speed increases the 'rotation' increases. But when I let off the accelerator it will stop. Also if I have the accelerator down and put in the clutch it stops. Any ideas?? Clutch going out?
Thanks in advance for any thoughts.
O2 In Sully We Believe
Old 05-28-2009, 05:18 PM
I think we will need more that that.
pitch
source
loudness
nature: grinding, or flapping, or scraping
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-28-2009, 05:37 PM
pitch
source
loudness
Ok, let's see...
PITCH, not quite sure, certainly not a high pitch.
SOURCE, kinda sounds like it's coming from the right rear of the car.
LOUDNESS, Fairly loud when starting out then mellows to a constant drone
NATURE, that's what I meant by rotational, certainly isn't a grinding noise nor flappling. maybe like clacking?
Old 05-28-2009, 05:48 PM
clutch or throwout bearing?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-28-2009, 05:58 PM
Bumpity-bump
Old 05-29-2009, 02:37 AM
Throw it on the ground!
Originally Posted by Buckterrier View Post
Bumpity-bump
...in the night?
Is your gear oil full/fresh?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-29-2009, 03:04 AM
Ruby911
ruby911's Avatar
Does it increase with increase in wheel movement or motor movement (i.e. does it change with speed of the motor or speed of the car)?
Probably nothing a new set of Altons and a 3.6 won't cure
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 05-29-2009, 03:22 AM
Originally Posted by mthomas58 View Post
...in the night?
Good thought Mark, it should be as it was changed late last year. But will check.
Me thinks it's motor. THe odd thing is the stopping completley when the clutch is engaged.
I do think the wheels would fix it! 3.6? na but will go faster.
Old 05-29-2009, 03:29 AM
CV Joints?
Old 05-29-2009, 04:21 AM
dshepp806's Avatar
Never seen a clutch engagement quieten a CV issue....
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-29-2009, 11:25 AM
What does it do when the car is in neutral, with and without the clutch engaged?
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
"Limping in the right direction is always faster than running the wrong way"
Old 05-29-2009, 11:49 AM
Zeke's Avatar
What happens to the noise each shift? I think you might have inferred that the noise went away on each clutch action, but I wanted to make sure.
If that's the case, I'm going to take a WAG and say check your trans and motor mounts.
Old 05-29-2009, 11:52 AM
Take a run, get up to speed, put it in neutral and that will tell you CV, wheel bearing, rotor issue engine or tranny mounts.....then turn while in neutral, thats when the wheel bearing, CV and mounts are stressed the most. Once you discount that, check the fan belt (with cold engine) to see if its loose. After start-up feel the top of the fan housing to check on an alternator bearing vibration. If all these are okay...continue to Plan B because........this is the extent of my knowledge. Best of luck.
I will tell you this.................a few weeks ago I was experiencing a crazy metallic noise in my left rear. It turned out that a small welded flange that connects the heat exchanger to the exhaust port (where muffler attaches) broke and the vibration caused a high pitched metallic sound!! Fixed in an instance.
Bob
Old 05-29-2009, 12:52 PM
mca mca is offline
mca's Avatar
Bob
Good advice there. Look at any and all fasteners - muffler straps, engine tin hardware, etc. It may be a simple fix. Things tend to come loose with constant vibration. Let us know if you discover the source.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 05-29-2009, 01:06 PM
