1974 911 w/ 83 SC engine
What's the heirarchy of handling for a 911?
Weight distribution
Center of gravity Track width Tire grip Weight How would one prioritize these characteristics to make a 911 the best handling car it can be, within its own constaints, of course? For example, is it worth sacrificing overall vehicle weight by having a heavier battery, spare tire, etc. up front giving better downforce and distribution, than not having them there at all (and losing the weight in doing so)? If you had to put these five attributes (and any others I might be missing) in a list, how would it look? |
Max Sluiter
Tires
weight weight distribution suspension tuning
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Non Compos Mentis
I'm no expert, but tire grip is absolutely, without question, number one.
1984-911 M491
Driver skill.
1984-911 TLC......SOLD |
Driver skill is #1
Mild Suspension tuning w/corner balance DOT-R Tires Brake cooling More suspension tuning Aero weight & distribution IMHO, a heavy/low powered car teaches you about momentum and smoothness. Once you can hustle a heavy car, weight reduction is icing on the cake.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
Yes, but that's a given. It's read. I am asking if "the Stig" got into a Porsche to drive it, what handling attributes of the car would be most important to him getting around the "Top Gear track" the fastest? And forgive me if these aren't recognized references, as they're only thing I figured most of us might know.
GAFB
I had been thinking in terms of...
0. Overcommit to corner 1. Don't lift 2. Don't lift 3. Don't lift 4. Don't lift 5. Lift 6. Countersteer 7. Counter-countersteer 8. Depress clutch pedal 9. Depress brake pedal 10. Kill ignition 11. Summon tow truck 12. Engage insurance adjuster 13. Post pics on Pelican But that's really more of an order of operations than a hierarchy. Carry on.
Several BMWs |
Check out Steve Weiner's Web pages on the topic:
Welcome to Rennsport Systems, Porsche Performance Products for the 21st Century Draw your own conclusions.
Motorsport Ninja Monkey
For a classic 911 ie limited to 150mph top speed being used on a road circuit I would go for
Tyres as nothing else comes in contact with the track and this ultimately controls which direction the car travels in. weight as most lap time will be spent either accelerating or braking. Less is best as it reduces loads on components and your braking efficency improves weight distribution/C of G as this will improve change of direction during cornering and the a low C of G will reduce lateral tyre deflection improving tyre grip. Sweet spot for front/rear weight distribution is 60-55% rear/40-45%front and as low as you can go on C of G I would also add chassis torsional/beam stiffness, suspension camber/toe stiffness as being very importantas there is no point trying to make a jello go fast as it will wobble all over the place. Obviously all this doesn't make up for the spacer betwen the steering wheel and the seat. |
Dog-faced pony soldier
I'd add: 4.5 Panic 9.5 Soil drawers 10.5 Bury head in hands, sobbing
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
slow in, fast out. for the track my priorities would be:
1) tires 2) minimize weight transfer front to rear with stiffer rear torsion bars.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Tires
Tires Tires and more. Yes on all the other but tires, tires, tires. My racing used a new set of race tires every day. Sometimes more. Even then it took very careful tire management. So long as everything else about a Porsche racer is just OK, tires are the single issue. Search some of my prior admonitions. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
In the early ‘70s Porsche built a ‘variable center-of-gravity’ 911. It had a cubic foot of lead on a vertical track through the horizontal plane CG. This ‘lump of lead’ was on a track where it could be just under the roof or through the pan almost touching the ground. I was told it would change the vertical CG by more than 2”.
There is a Christophorus technical article in ’70-’72 about the car and tests. I drove the car on the Weissach skid pad in May ’74. The conclusions were that a 2” change in vertical CG had about the same effect as the difference between Dunlap 165/78-15 street tires and the period Dunlap race tires. A BIG deal. So … To answer your question, vertical CG counts a lot. I understand one of the ‘tricks’ of F1 is to get the car very underweight and add the weight to spec with a tungsten plate under the chassis. This is so effective that F1 regulates the height with wood ‘rub strips’. Best, Grady
AutoBahned
Thx Grady - that is another amazing historical tidbit from you.
if pure lead, that would have weighed almost 708 lbs. I'm surprised that the cubic foot was not some metric unit however. |
1. C/G
2. gross weight 3. tires 4. dynamic load distribution 5. track (baked in by design)
1987 Carrera 3.2 Last edited by sig_a; 01-13-2010 at 04:33 PM.. |
Wow, that is a lot different than what others have listed, which is good, I like reading the differing opinions. I knew right off the bat though that I miss-communicated on my original post. By "track width" I meant the side to side distance between the tires--the wheelbase width-wise if you will--I guess I just didn't use the proper term for it. I knew immediately after posting it people would think I meant width of the track the car is driven on. Thanks for the responses everyone, this has been very educational for me.
First you make sure your suspension is in good shape, not sloppy or worn. Then you make sure you have good dampers. Then you get a corner balance, lowering, alignment. THEN you get tires. BRAKES must work |
Car handling priority
Tires,
but, Let's not forget unsprung weight. In talking with the guys at Jongbloed Racing Wheels, lap times (the effect of a good/bad handling car) was a common topic. Heavy to light wheels can be measured in "seconds per lap". Driving a car with lightweight wheels turns in faster, takes less distance to brake, and had a slightly faster acceleration. The overall distinction is a tighter feeling car - which is much more connected. A by-product is more sensitive tuning of springs and shocks. Having Fuch's has spoiled us. With 12 lb wheels we gain the handling without ever driving on 20 lb steel wheels to compare against. Sherwood's wheel weight study is here: 911 Wheel Weights The down side of very light wheels - they don't like potholes. |
[QUOTE=Fleming;5125569]Tires,
"Driving a car with lightweight wheels turns in faster, takes less distance to brake, and had a slightly faster acceleration. The overall distinction is a tighter feeling car - which is much more connected. A by-product is more sensitive tuning of springs and shocks." I can agree with that. Moving from 17" Fikse at 25" diameter to 15" Fuchs at 23" diameter improved handling in three distinct areas: lower C/G by 1"; reduced unsprung weight by about 40 pounds total; lowered final drive gear ratio about 8 percent. This is the single most impactive suspension modification so far.
1987 Carrera 3.2 |
