vinny c's Avatar
Headlight seal
Just got finished trying to install seal for headlights. Both seals split at glue joint. Tried to keep tension off joint when installing, but still no luck.
Any hints to make this easier?
What glue should I use to piece together?
Vince
Old 07-23-2011, 05:35 PM
47silver's Avatar
new ones less than 4 bucks from pelican
911-631-115-02-M136
less than 4 bucks each from our host
1975 911S Targa
Silver Anniversary Edition
Old 07-23-2011, 06:22 PM
6 cylinder symphony
When I broke my last one, I glued it with super glue - while I bought 2 more from PP.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 07-23-2011, 06:23 PM
vinny c's Avatar
These were brand new seals from our host. I' ll try super glue.
Vince
Old 07-23-2011, 07:06 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
vinny, i also had this problem, broke one, returned both--make sure you get the OEM porsche seals and not the repros.
There is a difference in quality, and be gentle!
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 07-23-2011, 07:10 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Tape down the glued end then gentle place the seal, use some dielectric grease to help it along, snap, that should do it. Once you are happy, carefully remove the tape.
Jim
'85 Carrera Targa
PCA/POC
Old 07-23-2011, 09:05 PM
I also brok one. Put the other in the sun for a while and gently stretched the material around the perimeter EXCEPT for the joint. I simply installed the broken on with the "break" at the bottom of the light
1986 3.2 Carrera
Old 07-24-2011, 05:48 AM
Nine9six's Avatar
Permatex Weather strip glue, available at any autoparts store, works just fine in glueing the ends back together. When doing this fix, I minimumally trim with a razor blade, both ends prior to glueing, and allow the glue to cure before handling and attempting to install. As stated previously, BE GENTLE, and use tape (masking) as DRACO Jim stated. Also, as Ben stated, you want to orient the break at the six oclock position.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 07-24-2011, 06:58 AM
joefrantz's Avatar
Per Draco & Nine9Six replies, these pictures may help.
Tack the seam to the fender with a dot of weather srtip cement in the six o'clock position and work your way around the circumference, taping as you go. The first two tape placements isolate the seam from the stretching. Also, note the correct orientation of the seal in the last pic.
Good luck
Joe
Joe Frantz
73 911 T
Old 07-24-2011, 07:28 AM
vinny c's Avatar
Thanks to all. Was able to reglue and install, gently this time.
Vince
Old 07-24-2011, 12:50 PM
DRACO A5OG's Avatar
Old 07-24-2011, 01:49 PM
AutoBahned
RWebb's Avatar
another tidbit
Old 07-24-2011, 02:43 PM
wayner's Avatar
Is the seal mentioned here the correct one for H4 headlights?
(seal 911-631-115-02-M136 )
My kit was included in a box of parts from the previous owner and did not include the seals
Thanks in advance.
SOLD - 914 wide body hot rod
Old 08-31-2012, 02:09 PM
porwolf's Avatar
Thanks in advance.
That is the part number of the Pelican seals that I used recently when I installed new H4's on my 79SC. I followed pretty much the instructions on this thread. I used silicon glue on both sides of the rubber rings to better seal against the fenders and the H4 rings. Also it makes the final mounting of the H4's easier and they act not so sticky against the seals.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 08-31-2012, 03:31 PM
Irrationally exuberant
ChrisBennet's Avatar
The ends of my H4 seals came unglued as well. I just sewed them together with a needle and black thread. A couple stitches is all it took.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-31-2012, 07:13 PM
Exotic Vehicles are here
1-ev.com's Avatar
Sorry for silly Q, but what this pic represents?
Thank you,
another tidbit
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 09-02-2012, 07:05 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Not quite sure but if you look at the white car pic you can see the edge on top of the bucket that the headlight ring had to go over to get hooked into place. At least that is what I remember when I replaced my rings. I had reproductions from S t o d d a r d and they were fatter than original. It was a pain.
Old 09-02-2012, 07:22 AM
AutoBahned
RWebb's Avatar
the pic is a cross-section thru the seal, aka gasket
the J lip below it is the mtl flange around the headlight
BTW - these seals have only a partial join at one point and that is where they break - maybe it was purposeful to allow water to drip - who knows
Old 09-02-2012, 12:22 PM
Old thread but very helpful! I struggled with orientation on seal profile - this thread fixed me up!
Old 08-29-2016, 05:19 PM
DRACO A5OG's Avatar
cool
'85 Carrera Targa
PCA/POC
Old 08-29-2016, 05:24 PM
