Headlight seal
Just got finished trying to install seal for headlights. Both seals split at glue joint. Tried to keep tension off joint when installing, but still no luck.
Any hints to make this easier? What glue should I use to piece together? Thanks Vince |
new ones less than 4 bucks from pelican
911-631-115-02-M136
less than 4 bucks each from our host
1975 911S Targa Silver Anniversary Edition |
6 cylinder symphony
When I broke my last one, I glued it with super glue - while I bought 2 more from PP.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
These were brand new seals from our host. I' ll try super glue.
Vince |
vinny, i also had this problem, broke one, returned both--make sure you get the OEM porsche seals and not the repros.
There is a difference in quality, and be gentle!
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Member 911 Anonymous
Tape down the glued end then gentle place the seal, use some dielectric grease to help it along, snap, that should do it. Once you are happy, carefully remove the tape.
Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I also brok one. Put the other in the sun for a while and gently stretched the material around the perimeter EXCEPT for the joint. I simply installed the broken on with the "break" at the bottom of the light
1986 3.2 Carrera |
Permatex Weather strip glue, available at any autoparts store, works just fine in glueing the ends back together. When doing this fix, I minimumally trim with a razor blade, both ends prior to glueing, and allow the glue to cure before handling and attempting to install. As stated previously, BE GENTLE, and use tape (masking) as DRACO Jim stated. Also, as Ben stated, you want to orient the break at the six oclock position.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 07-24-2011 at 06:00 AM.. |
Per Draco & Nine9Six replies, these pictures may help.
Tack the seam to the fender with a dot of weather srtip cement in the six o'clock position and work your way around the circumference, taping as you go. The first two tape placements isolate the seam from the stretching. Also, note the correct orientation of the seal in the last pic. Good luck Joe ![]() ![]() ![]() ![]()
Joe Frantz 73 911 T |
Thanks to all. Was able to reglue and install, gently this time.
Vince |
AutoBahned
another tidbit
Is the seal mentioned here the correct one for H4 headlights?
(seal 911-631-115-02-M136 ) My kit was included in a box of parts from the previous owner and did not include the seals Thanks in advance.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
That is the part number of the Pelican seals that I used recently when I installed new H4's on my 79SC. I followed pretty much the instructions on this thread. I used silicon glue on both sides of the rubber rings to better seal against the fenders and the H4 rings. Also it makes the final mounting of the H4's easier and they act not so sticky against the seals.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Irrationally exuberant
The ends of my H4 seals came unglued as well. I just sewed them together with a needle and black thread. A couple stitches is all it took.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 09-03-2012 at 03:59 AM.. |
Exotic Vehicles are here
Sorry for silly Q, but what this pic represents?
Thank you,
"Y" <- My favorite question... + '68 911 + Helping your business to get more business: http://myWWWapp.com |
Fleabit peanut monkey
Not quite sure but if you look at the white car pic you can see the edge on top of the bucket that the headlight ring had to go over to get hooked into place. At least that is what I remember when I replaced my rings. I had reproductions from S t o d d a r d and they were fatter than original. It was a pain.
AutoBahned
the pic is a cross-section thru the seal, aka gasket
the J lip below it is the mtl flange around the headlight BTW - these seals have only a partial join at one point and that is where they break - maybe it was purposeful to allow water to drip - who knows |
Old thread but very helpful! I struggled with orientation on seal profile - this thread fixed me up!
cool
Thread Tools | |
Rate This Thread | |
