With that setup you could install almost any third party muffler(s) you wanted. I guess I missed the track car part.
72 911 Although it is done at the moment, it will never be finished. |
Yes, I can make any muffler work, just need one that does the "magic" of making power while knocking sound down to sud-90db..
Gary R. |
Administrator
I recently switched from the Flowmaster to a (smaller) Magnaflow, and was surprised that the new setup is quite a bit quieter. One other change is 993 headers instead of B&Bs. But the Magnaflow did very well on the dyno and -- especially on track days -- I actually wish it were a little bit louder.
Old Flowmaster: big. ![]() Magnaflow: small. ![]()
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Jack - would you remember which model Magnaflow it was?
Thanks! Gary
Gary R. |
Gary,
I like Jack's set up. Wanna share the cost of buying 1 kit to experiment? then we'll split the cost of the 2nd kit of kit 1 proves adequate. Also, i found a treasure chest of 15 inch wheels this morning ![]() Fred |
Also need to get an opinion on which way to point the tailpipes to minimize any readings. I was thinking straight down but then there may be an amplification bouncing off the asphalt. Set them the way Jack has them and it may be best as they only measure from one side.. if the muffler is quiet enough it won't matter.
Gary R. |
Yes, absolutely, and even in daily use in some applications. Electronic "anti-noise" engine mufflers have been around for quite some time now. It's possible they could even be switched off and on if one wished to do so. Most commonly used on diesel engine power generators in urban areas, QUIET zones, hospitals, etc. |
just me
put a turbo on it! they are quiet
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Been here a while
for lime rock, I would dare say point towards the passenger's side.....most times I've seen them taking measurements, it has been along the driver's side....also, this will be quieter for the driver.
agreed, down will amplify the sound you could point them towards each other, and hope they will be cancel each other out ![]()
looking for 1972 911t motor XR584, S/N 6121622 |
Navin Johnson
This is my Lime Rock set up. The car has headers and a M&K RSR muffler. I got a cap for one side, an elbow, and a baffle.. I can obviously switch the cap and elbow side to side, aim the elbow etc..
Also on the headers I had v band clamps installed so I can easily put on megaphones.. ![]() ![]() ![]()
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Navin Johnson
oops pic posting error
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 10-21-2010 at 12:53 PM.. |
Navin Johnson
the whole shebang
That's the sort of thing I was referring to, except of course it's in steel instead of c/f
Lot's of internal volume to absorb the noise
teaser pics:
![]() ![]() ![]() Last edited by Steve W; 10-21-2010 at 03:01 PM.. |
Administrator
Model 11386 - currently $81 at Amazon and it's stainless.
There are bigger models, but I needed to squeeze between the outlets of 993 headers. Here's a picture of how it works: ![]() I'm trying to figure out Steve's. Is that a solenoid for a bypass valve?
Diss Member
If so which was quieter?
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I would think I would use the biggest one I could fit, similar in size to the FM 80..
Gary R. |
Administrator
No, I had a Flowmaster. I never took measurements, but my belief is that the Magnaflow is quieter. Again, though, it could also be because the 993 headers might be quieter than the B&Bs.
Crotchety Old Bastard
The muffler Steve is using looks to be from a late model 911GT3. Not an inexpensive solution, and when the valves open, not quiet. Very cool street system though.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thread Tools | |
Rate This Thread | |
