3.6 variants question
As I attempt to educate myself per expected 3.6 swap into my 86 Carrera I am curious to know differences among 964/993 engines. Am familiar with Varioram lash up but would like any input concerning 3.6 overall variants.
Thanks EP Slick
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Hi Paul,
964 3.6 has around 250 hp 993 3.6 w/o Varioram has around 270 hp ...diff between this and the 964 is the head, maybe valves, and definitely exhaust. OBD-I Varioram 993 has 282hp and a ton more torque due to larger valves, vram flapper thinggie which you can retrofit back to older 993. OBD-II You can add vram to an earlier 993 pretty easily. |
Look at Bill Verburgs 964 vs 993 sticky at the top of the 964/993 tech forum.
My take on differences is: Very early 964 engines didn,t have head gaskets and have had leak issues. > late 964 engines switched to a plastic intake which is supposed to flow better. >993 has a lighter crank and I think the 964 uses a harmonic balancer pulley. >993 exhaust flows better and that might explain most of the 30 hp difference > 993 in 96 adapted a varioram intake system increasing hp and torque over the 95. > 993 uses hydraulic lash system,eliminating routine valve adjustments
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
The top 2 IMO are '94-95 993 & '96-98 RoW vram 993 due to their simpler OBD1 electronics and improved architecture primarily in the heads and air metering next is 964 still has simpler 55 pin OBD1 electronics hardest to do is the '96-98 US vram 993 w/ it's 88 pin OBD2 electronics
Administrator
There's also some good information here.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Thanks all
Thanks to all for the input.
Now will one of you please send me an engine for my planned project. Ep slick
