Very nice project!
With your vision, thoroughness, level of attention, and high standard of craftsmanship, my friend - have you given any thought to doing this on a full time basis? I'm sure you'd have a waiting list on potential clientele... Keep on with the good work - its beyond first rate!
@ Walt : "holes of the cash deck" is not the good word you knowit, i have search the real word for this in pelican and i think the good word is "Lower Side Rocker Cover" and in the car you have hole for the screw of this part and because we have no need of this part we will have to erase this hole
@Otto : i'm just a little guy who have pleasure to realize his dream of RSR with not a lot of money, but lots of idea and DIY ![]() @All the another fellow : thanks for th read of my post and your support
www.2l7registry.com the Ultimate register website for all 911 2.7 for 74 to 77 |
Recoveryof a rear light which I bought to replace mine from which connections had died.
I do not know in what is made the light but it was great oxidized. ![]() Complete sanding ![]() Then cold galvanization. ![]() Idem for the supports of seats, sanding and galvanization. ![]() Then first coat of paint of finish ![]() Special thanks to René who has give me its crowbar Dymo, and I managed to find of the ribbon 9mm black whom I would have on Thursday. ![]() A view of the dashboard for the moment. ![]() And today, finally a little sun thus authorized outdoor work. Sanding of the extensions. ![]() ![]() Assembly of the bumper and creation of the fixations ![]()
Then location of lights for a back global view ................. so bestial.
![]() ![]() ![]() The dream arrived
Max Sluiter
I am impressed you got that work done with Voekler finishing in 4th overall in the Tour and Roland winning Alp d'Heuz.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
yes flieger Voekler 4th
![]() Bu today a good news, the last part i waiting for are just arrived, the project is completed. ![]() ![]() ![]() and no fuel hole ![]() ![]()
so Fellows for you have not to waiting more ......................
![]() little mounting with "scotch" and a view like it's finish ..... ![]() ![]()
Congrats on getting this far! Car looks great!
1975 Aubergine 911S - Barney "When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson |
Max Sluiter
Very nice. Where are the fenders/wings/flares from? GT Racing?
I think Voekler and Roland did very well, especially considering team Europcar was a "wild card" entry.
They come from deutschland , f-s-h .
Yesterday evening as it worked me I looked of more meadows at the assembly of wings.
Two famous parts R and L, which I planned to sell, are thus going to stay on Froggy to finish but it's going to need to cut them a big piece to each. I am just going to cut after the bolt to fix the bowl of headlight (in metal and of brand Dansk) ![]() Then assembly of the internal cheek ![]() It will be necessary to stick the wing above Then assembly and in the final it is very clean, only two place must be a little modified ![]() A bump of fiber before the hole of lived that it's going to need to sand to level. ![]() The outside edge of the side wing support to level also a little Otherwise that should make it. I do not know how he make their mould but we see the good place of holes
Max Sluiter
So the bolt holes line up well but the panel gaps need some filling and sanding.
Are the yellow "famous parts" that you are going to cut the bumper brackets?
Wings are not fixed, just put. After the holidays I am going to fix the whole, and I would take back with some picture, the distance will not be any more there.
The yellow legs, go to be cut by the party which was fixed on bellows of the old impact bumpers. And i must cut it because if i do not i can't take the indicator light in this place. i have received the new chronometer and will just finish the support. ![]() Now next news in the end of August Month, good holiday to all of you and your familly ![]() ![]()
Hello Guys, i'm back from holiday, and which says "back from holiday" said "already begin the work on Froggy".
Thus I have begin slowly. I continued by painting of the supports of seats ![]() And fixed rails on the automobile (by having taking care of concealing everything) ![]() What makes that the inside is close to the end. I found my red pull " Fire " and I am soon going to order it. Then will stay the sky of roof and the parts of imitation leather of the amounts of car doors and it is everything (finally until the next idea in ....... ![]() As I found of the ribbon " dymo " I was able to make my labels ![]() And set up them ![]() Then I got down to the adjustment of wings and hood before.... ![]() ![]() And there I have some big doubt on several point, so i think this job will be not so funny. but when we have to go ...... we must go !
nice project.
I did not see your final answer on this, is the fit of the fiberglass panels good? I purchased some fiberglass items in the past and it was disgusting how bad the fit was. I am also building a RSR body but I decided to use the original steel fenders and have turbo flares welded in...... |
Hi Herman
All the manufacturers of fibers are not identical, some parts are very thick with very beautiful finishes of the other one are very fine without any reinforcement and with very bad finishes, it is necessary to read a lot to have experience feedback of the other fellows. For me some part are second-hand thus already gone up and adjusted, there no problems, the fenders and rear bumpers are new and fenders a little of work but not too much. The new parts were ordered in Germany because you have very good parts in United States but with the transport and tax, finally the prices are 1.5 or 2 times more expensive while cheaper on the base!!! the dream is to use all parts in steel but the final price is very different. you have a thread for your RSR Build ?
where are the fenders from? sorry if i missed that
Jim,
the rear ar steel turbo fender made by dansk (and sell by all good porsche part society ... like pelican) the front come from deutschland , from society FSH (FSH - GFK Leichtbauteile passend für Ihren Porsche)
Thread Tools | |
Rate This Thread | |
