Updated photo's of the body... Having had the car walnut blasted, the entire car is almost all lined up and ready to paint....
James 1973 911T - 3.6VRAM, G50/5Speed 1978 to 1973 Turbo with RSR Look, 3.8Ltr TT, G50/6Speed 2010 GT3RS |
The side bars are generally not allowed to be welded in as the view is they impede access and egress in an emergency - same reason you are not allowed to wear full harness seatbelt on the road. Would love to see the car at a Porsche Club of NSW track day when it gets here. Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. |
mph911
Matt Hart - Instagram @the_escape_road |
I'm fairly sure that this is the case as well.
The rules from what I can see are very difficult to deal with. IE certain front cages could get approved - such as those hard up against the firewall. But these cages cannot connect to the rear - only by bolt in for these sections... Also newly manufactured and registered vehicles have it easier in a round about way... The joys of the RTA in NSW.
Update from Patrick Motorsports
So, my project has been deemed worthy of the Patrick Motorsports website. You can visit the link
Most of the images I have posted are on the forum, but there are a couple of things that have been left off. Hoping to have the long block pictures to be posted later this week.
James 1973 911T - 3.6VRAM, G50/5Speed 1978 to 1973 Turbo with RSR Look, 3.8Ltr TT, G50/6Speed 2010 GT3RS Last edited by JEM911; 08-23-2011 at 06:14 PM.. |
Patrick Motorsports - 1974 Carrera RSR Twin Turbo Essentially because we have to fit the 993TT engine (including inter-coolers), you need to fabricate a 'new' deck-lid with clearance.
I see. So it'll kind of be like a whale-ducktail. They flatten the top to clearance the intercooler. I figured it had something to do with the intercoolers, but was just curious. I wasn't sure if they'd use the OEM routing of the intercooler, or if they'd take Ruf's routing and lay the intercoolers on either side of the engine inside of the engine compartment. So I see that they'll be using the OEM routing.
Fantastic project. Last edited by will hung; 08-25-2011 at 05:06 AM.. Reason: additional comment. |
Max Sluiter
So they are going to cut holes/slots in it later?
I have seen 930s with custom bent/cut+welded intercoolers that fit under normal ducktails without shrouding.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
There will be holes cut into them eventually once the final gaps are all sorted on the body.
It's better to get the most efficient design / layout for the engine, then get the body to fit afterwards.
Long Block
Got further pictures today of the engine build...
In high fill prior to paint
What a difference a week and a bit makes, the car is almost ready now!
Attached are the pictures of the high filled car just about ready for paint. I'm so excited now, I can almost see the car put together! admittedly i know its a bit longer to go but its a big step ![]()
Got the seats today...
We got the seats on Friday which is awesome. The wheels are due next week....
![]() Paint has been a pain in the ass. For some reason the slate grey code seems to be different from a few different paint companies. There's a bit of difference, but I'm close to getting it right. At the end of the day I don't really think it's going to matter, as the car isn't original in any event, but I do want to get it as close to right as possible. The set back with color has put this all back a bit. Hopefully we will be on track this week.
Test fitting prior to paint
So because we needed to cut out the duck tail, and it obviously needed to occur prior to being painted, the car's been back in fabrication getting the last test fit prior to painting.
The long and short of it all is that we've moved the engine forward as much as possible to get clearance on the inter-cooler. We also need this because there isn't a great deal of room for the exhaust back there, so it's a lot easier to do the test fit now, without the worry of paint than after paint has occurred. Also it was decided that we should prepare and test fit all the oil lines etc now, include fabricate any brackets, clip spots, etc, so they all get painted and look as factory as possible. The long and short of it is that it's not seeing paint this week. ![]() but you do get to seem some photos of the car coming together... ![]() which is a small consolation prize, because it's looking good.
It DOES look good!!
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
wow...
Jon |
Great looking car
Everything looks so perfectDo you use brackets for holding the turbos or are they sitting on the exhaust pipes? |
superb car
(are you sure about the colour? ) |
I like watching.
S |
