LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Updated photo's of the body... Having had the car walnut blasted, the entire car is almost all lined up and ready to paint....
James
1973 911T - 3.6VRAM, G50/5Speed
1978 to 1973 Turbo with RSR Look, 3.8Ltr TT, G50/6Speed
2010 GT3RS
Old 08-22-2011, 08:02 PM
Mothy's Avatar
Send a message via AIM to Mothy
Originally Posted by JEM911 View Post
Yes! How stupid is this system?
There are three essential 'issues' they have with the roll cage.
1. The cage running down along the A-Pillar would 'block your view' - so you can't drive safely
2. The cage intrusion bars protecting driver from a side impact are unsafe because in an accident they will crush you, and you will die (or some similar stupid logic)
3. A cage in the front near the firewall etc will also kill you in a accident because it will crush you (see comment on point 2).
It's the dumbest approach is the world. It's really driven by people who have done dodgy cages, then been in accidents. They don't think as far motorsports success with using cages to 'survive', only the fact that in an accident, done wrongly will impede you chances of surviving.
You might want to check a bit further with some of the Sydney Porsche shops - If what you say is correct, then how do they get GT3RS's registered in NSW? They have a full cage with only the side bars as bolt in.
The side bars are generally not allowed to be welded in as the view is they impede access and egress in an emergency - same reason you are not allowed to wear full harness seatbelt on the road.
Would love to see the car at a Porsche Club of NSW track day when it gets here.
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 08-22-2011, 08:28 PM
giovanni86's Avatar
Old 08-22-2011, 11:46 PM
mph911
Tim
Im pretty sure they are registered with the back half of the cage and the front section and sidebars bolt up.
Matt Hart - Instagram @the_escape_road
Old 08-22-2011, 11:58 PM
I'm fairly sure that this is the case as well.
The rules from what I can see are very difficult to deal with. IE certain front cages could get approved - such as those hard up against the firewall. But these cages cannot connect to the rear - only by bolt in for these sections...
Also newly manufactured and registered vehicles have it easier in a round about way...
The joys of the RTA in NSW.
James
2010 GT3RS
Old 08-23-2011, 03:15 AM
Update from Patrick Motorsports
So, my project has been deemed worthy of the Patrick Motorsports website. You can visit the link
http://www.patrickmotorsports.com/project/57/
Most of the images I have posted are on the forum, but there are a couple of things that have been left off.
Hoping to have the long block pictures to be posted later this week.
James
2010 GT3RS
Old 08-23-2011, 06:04 PM
Out of curiosity, why is the engine cover grill filled? Awesome project.
Old 08-24-2011, 04:51 AM
The probably best explanation is on the Patrick Motorsports website:
Patrick Motorsports - 1974 Carrera RSR Twin Turbo
Essentially because we have to fit the 993TT engine (including inter-coolers), you need to fabricate a 'new' deck-lid with clearance.
James
2010 GT3RS
Old 08-24-2011, 02:20 PM
I see. So it'll kind of be like a whale-ducktail. They flatten the top to clearance the intercooler. I figured it had something to do with the intercoolers, but was just curious. I wasn't sure if they'd use the OEM routing of the intercooler, or if they'd take Ruf's routing and lay the intercoolers on either side of the engine inside of the engine compartment. So I see that they'll be using the OEM routing.
Fantastic project.
Old 08-25-2011, 05:05 AM
Max Sluiter
Flieger's Avatar
So they are going to cut holes/slots in it later?
I have seen 930s with custom bent/cut+welded intercoolers that fit under normal ducktails without shrouding.
Old 08-25-2011, 10:50 AM
There will be holes cut into them eventually once the final gaps are all sorted on the body.
It's better to get the most efficient design / layout for the engine, then get the body to fit afterwards.
James
2010 GT3RS
Old 08-25-2011, 06:57 PM
Long Block
Got further pictures today of the engine build...
James
2010 GT3RS
Old 08-27-2011, 12:43 AM
In high fill prior to paint
What a difference a week and a bit makes, the car is almost ready now!
Attached are the pictures of the high filled car just about ready for paint. I'm so excited now, I can almost see the car put together! admittedly i know its a bit longer to go but its a big step
James
2010 GT3RS
Old 09-01-2011, 07:35 PM
Got the seats today...
We got the seats on Friday which is awesome. The wheels are due next week....
Paint has been a pain in the ass. For some reason the slate grey code seems to be different from a few different paint companies. There's a bit of difference, but I'm close to getting it right.
At the end of the day I don't really think it's going to matter, as the car isn't original in any event, but I do want to get it as close to right as possible.
The set back with color has put this all back a bit. Hopefully we will be on track this week.
James
2010 GT3RS
Old 09-24-2011, 12:52 AM
Test fitting prior to paint
So because we needed to cut out the duck tail, and it obviously needed to occur prior to being painted, the car's been back in fabrication getting the last test fit prior to painting.
The long and short of it all is that we've moved the engine forward as much as possible to get clearance on the inter-cooler. We also need this because there isn't a great deal of room for the exhaust back there, so it's a lot easier to do the test fit now, without the worry of paint than after paint has occurred.
Also it was decided that we should prepare and test fit all the oil lines etc now, include fabricate any brackets, clip spots, etc, so they all get painted and look as factory as possible.
The long and short of it is that it's not seeing paint this week.
but you do get to seem some photos of the car coming together...
which is a small consolation prize, because it's looking good.
James
2010 GT3RS
Old 10-05-2011, 02:55 PM
wayner's Avatar
It DOES look good!!
SOLD - 914 wide body hot rod
Old 10-05-2011, 03:03 PM
shbop's Avatar
wow...
Jon
Old 10-05-2011, 06:16 PM
MrShades's Avatar
Great looking car Everything looks so perfect
Do you use brackets for holding the turbos or are they sitting on the exhaust pipes?
Old 10-06-2011, 10:21 AM
giovanni86's Avatar
superb car
(are you sure about the colour? )
Old 10-06-2011, 10:56 AM
I like watching.
S
Old 10-06-2011, 12:25 PM
