I'm not sure I've ever seen raised spindles on an early 911. Common as rain in Seattle in the VW world.
Well, it is common for LWB cars. Most of the high budget builds of RS or RSR replicas used raised spindles. At least out here.
They are fabricated. Some even drop the spindles to raise the ride height on rally cars.
Clint at Rebel Racing does it, Chuck at Elephant does it, any of those guys can do it. TRE I think sends them to ER or RR. |
I don't know the range of motion that flipping the bracket will give you but I am not dumping the car on the ground like a dedicated track car. It will be mildly lowered so that it is still streetable/cross country trip worthy. I have priced out the spindle drops and ROI puts it low on the priority list. Very trick mod though! (Raising the spindles was a factory mod for the racecars no?) |
Acorn nuts?! This is a bastard hot rod...not a squirrel ;) |
Brian, You have the skill. You just need an enabler to point you in the direction of suspension setup.
I am that enabler. http://forums.pelicanparts.com/porsche-911-technical-forum/480047-koni-struts-raised-spindles-how-few-question.html |
Keep the work mov'n.. |
My car had binding. I have score marks on the Tarrett drop links to prove it. My car wasn't that low, either.
I modified the front struts to raise the spindles on my SWB; it required making new shock tubes and adding a spacer between the spindle casting and the bottom plate. Did this was about 22 years ago.
Clint was working on raising some SWB spindles a few weeks ago. Its quite different from the LWB operation.
Day 259 || Progress...and small glimpses of light at the end of the tunnel
22Mar2012 Tried to get some help with ignition switch swap...no luck from the Pelican mindtrust.. https://lh3.googleusercontent.com/-f...2520Mayhem.JPG Ground out any suspect areas + all around the seam to lock down the minor rust issues https://lh3.googleusercontent.com/-K...-03-06_649.jpg viola! https://lh6.googleusercontent.com/-M...-10-48_437.jpg https://lh4.googleusercontent.com/-0...-16-09_922.jpg https://lh4.googleusercontent.com/-j...-15-21_949.jpg Tested the electrical and the fan was making an awful noise so I decided to pull it, fix the noise and do some 'while I am in there' stuff. https://lh3.googleusercontent.com/-9...-07-29_870.jpg https://lh4.googleusercontent.com/-R...-08-59_539.jpg This 'ring' for the fan blades looked like it came off at some point. The blades seem structural enough to go without it https://lh3.googleusercontent.com/-j...3-09-26_24.jpg picked up some 2mm 'craft' store foam to rebuild the valve seals that dried up and went TU some time ago (one is in the background) https://lh3.googleusercontent.com/-q...-32-03_858.jpg I also built up a new gasket out of the 2mm foam for the motor to intake housing https://lh4.googleusercontent.com/-j...0-30-53_48.jpg |
Day 259 ||...cont. Progress...and small glimpses of light at the end of the tunnel
22Mar2012 The drainhose for the intake housing died long ago and we can't have water draining into the trunk so without a replacement or heavy chunk of hose I 'formed' a hose using large heat shrink tube and then pulled the blue hose https://lh5.googleusercontent.com/-Z...-41-10_541.jpg Tank installed. Not a perfect fit but close enough for a bastard hot rod :p https://lh4.googleusercontent.com/-1...-14-44_737.jpg https://lh6.googleusercontent.com/-C...-14-59_510.jpg https://lh3.googleusercontent.com/-s...-15-34_559.jpg Something I did not anticipate. The fit is almost net fit on the filler tube next to the strut brace. I was able to tweak the tube out enough to clear https://lh3.googleusercontent.com/-z...-15-47_139.jpg recovered the tank hold down clips with double wrap of shrink tube. Not the factory light gray but it will work for this iteration of the build https://lh5.googleusercontent.com/-k...-16-07_131.jpg I had to install it to to see what it will look like 'finished' https://lh6.googleusercontent.com/-x...-26-58_869.jpg https://lh5.googleusercontent.com/-X...-27-11_454.jpg https://lh3.googleusercontent.com/-I...-27-29_203.jpg |
Now on to the important things. Like getting it running. Wait until you drive it without a hood or fenders. Talk about lightweight.
Looks really good. |
Awesome progress! The trunk turned out really nice.
Bryan, looking good!
So in hindsight would you have moved the drivers side strut bar support slightly back toward the brake fluid reservoir to give more room for the fuel tank inlet tube? Just asking in advance of doing mine. Hope it turns out half as nice as yours. |
| All times are GMT -8. The time now is 08:52 AM. |
