I do indeed have the old plate but it is in bad shape. The edges around the holes are broken and there is a big dent in the middle. It is also the wrong paint code!! |
Just thought I would post a quick update and laundry list remaining to finish the project.
This Thursday Peter is going to come over and we will try to install the headliner!! After the headliner is done I will have the following tasks to complete before the Rat is back on the road:) Finish Thermocoustic liner install Install fuel tank vent system Install quarter windows with new seals and cleaned and polished trim Address issues with lights on driver side rear Install carpet and interior ( I will have the seats refinished at some point down the road) Install door seals Finish work on the dash and install Bleed brakes Install S rocker trim Install front and rear glass Clean up the engine bay Put on hood crest :cool::D Get new appraisal and alignment |
hey - can I get you guys to weigh the headliner and the metal bows on an accurate scale?
Inquiring Minds WANT to Know... |
Day 84: Today Peter and I were able to install the headliner and finish the sound deadening material on the passenger side. Thanks for all the help Peter. Without you and your awesome T-shirt the headliner would still be lying on our guest bed :-) Sorry Randy I did not weight it before it went in as I do not have an accurate scale at home. I have the old headliner and could weigh it at the university without the bars if that helps you. Overall the install went great and I would like to thank everyone that posted regarding the headliner install. Using the excellent write up and video below the task was a 3 out of 10 so don't be afraid to tackle it yourself. As long as you have plenty of clips, 4 hands, Weldwood Contact Cement, patience, and a good quality headliner from Pelican this job is easy. Peter and I took about 3 hours to get the headliner installed and I still need to fold and glue the excess material over the lip this weekend.
http://forums.pelicanparts.com/porsche-911-technical-forum/666633-part-1-headliner-install-dont-scared.html 911 68 headliner fitting with Gary Cook.wmv - YouTube Here are some pictures of the install http://forums.pelicanparts.com/uploa...1354247784.jpg http://forums.pelicanparts.com/uploa...1354247807.jpg http://forums.pelicanparts.com/uploa...1354247846.jpg http://forums.pelicanparts.com/uploa...1354247873.jpg http://forums.pelicanparts.com/uploa...1354247906.jpg http://forums.pelicanparts.com/uploa...1354247936.jpg |
Great work!
I've gotta do this after I've finished welding in the drivers floorpan, and seeing you give it a 3 out of 10 has really encouraged me! Also gonna use the Eastwood sound deadening, they sell it as a complete kit here in Blighty It's got damn cold here in the UK this last week, but I'll wrap up warm and keep you posted on progress Still not had the time to start my own thread! Keep up the fantastic work! Tony |
Congratulations on getting your headliner in! It looks great! How long until the maiden re-voyage? When finished, you should drive up to Tampa for a Cars & Coffee at either the Dupont Registry (huge) or Reeves Import Motorcars (small compared to Dupont but growing)... You have a place to stay at our house if you ever do.
Jeremy |
I made some fantastic progress today. I was able to finish the headliner and got vinyl installed on all of the pillars. I was also able to install the chrome trim at the bottom of the quarter windows. Currently my wife and I are getting ready to go and swim with manatees so I will post pictures tomorrow!
The headliner looks really nice. Thanks for mentioning that it's not too terribly difficult. Looking forward to putting mine in...whenever that may be. Anything tricky about putting the vinyl back on the pillars? I took many photos of where the folds in the vinyl were when I took mine out. It looked like it would be easy to put it back...but there are many things about my restore that I thought would be easy when I started. Like....umm....currently I'm stuck drilling out what seems to be thousands of spot welds to replace the rear crossmember. The spotwelder who put on my rear crossmember must have really loved his job. He went nuts with them. What a pain in the...
Putting in the vinyl was not tricky at all. Once you get good at using the Contact Cement and make sure to time the glue everything is straight forward. I would give installing the vinyl trim a 2 out of 10. Having the old pieces as a template was very helpful for cutting things to the correct size. Good luck with the spot welds:( |
Day 85 Finishing up the headliner: I was able to finish up the headliner and trim all of the excess. I was also able to install all of the vinyl trim on the A and B pillars. Overall, the job of the headliner and the vinyl trim was not that difficult, only time consuming. I have a few spots that I am going to hit with a steamer but overall I am really happy. If you are patient you can do this no problem. I really don't understand what everybody is afraid of. Here are some pictures from finishing the headliner install and installing quarter window trim.
Using the old vinyl trim as a template http://forums.pelicanparts.com/uploa...1354547287.jpg Lower driver B pillar vinyl glued into the lip and waiting for the contact cement to set to finish the job http://forums.pelicanparts.com/uploa...1354547334.jpg Finished upper B pillar http://forums.pelicanparts.com/uploa...1354547407.jpg Finished lower B pillar http://forums.pelicanparts.com/uploa...1354547448.jpg Top of the doors installed http://forums.pelicanparts.com/uploa...1354547521.jpg |
Day 85 continued:
Driver A pillar vinyl trim completed. I left the clips on overnight to make sure the glue was set http://forums.pelicanparts.com/uploa...1354547606.jpg Quarter window trim installed. I used the Terostat ribbon to seal the chrome trim and made sure to place the spacers in the correct spots. The thinnest spacers start toward the rear of the car with the thickest spacer being closes to the door jamb. Towards the rear of the window I only used one thickness of Terostat ribbon. At the middle I used two thicknesses and in the front I used 3 strips stacked up on top of each other. I also made sure to put Terostat on the lip that the chrome trim fits over. http://forums.pelicanparts.com/uploa...1354547661.jpg Test fitting the interior vinyl :D:D Once the carpet goes in all of this goes back in as well !!!!:):D http://forums.pelicanparts.com/uploa...1354547918.jpg After working on the car for about 8 hours I was sick of "Rat" work and went and picked tomatoes instead. Having a garden is one of the most relaxing and rewarding things a man can do:D:cool: http://forums.pelicanparts.com/uploa...1354548025.jpg |
I am getting ready to install the quarter windows with new seals and have been doing some research. It looks like it might be a pain but the following two links should help
Rubber Seal http://forums.pelicanparts.com/porsche-911-technical-forum/495432-quarter-window-seal-pop-out-window-installatiion-question.html Fitting pop out window to later 911s http://forums.pelicanparts.com/porsche-911-technical-forum/347620-install-pop-out-rear-quarter-windows.html |
If anyone is interested I have my old headliner and the old vinyl from the A and B pillars available. These came in really handy as a template. I could include all of the clips I used for the headliner and ship the entire thing as a "package" for headliner and vinyl install. I hope that somebody can use this stuff to give life to another 911 now that I am done with it. Please PM me if you are interested.
Day 86 Gas tank vent system installed : Today I was able to install the gas tank vent system using the exact setup from 69.
Vent tank http://forums.pelicanparts.com/uploa...1354555519.jpg While I was inspecting the area where the tank goes I found an old original rubberband used to hold the tank in place. The rubber band was really brittle so I replaced it with some thin bungee cord. http://forums.pelicanparts.com/uploa...1354555710.jpg To install the vent tank I needed to remove the hood shock on the drivers side. To hold up the hood during this operation I used three tubes from my shop vac;) http://forums.pelicanparts.com/uploa...1354555817.jpg At first I installed the vent tank using clear vinyl tubing for both the inlet and the outlet. The inlet hose from the gas tank kept kinking so I replaced it with a rubber hose. The picture below shows the original install with vinyl tubing and the kink. http://forums.pelicanparts.com/uploa...1354555937.jpg After I installed the tank I plumbed the brake reservoir vent line and the vent tank outlet line into a T fitting. I found a really clever fitting at ACE Hardware that allows you to fit different size hoses by cutting off smaller fittings until your correct size is reached. The fitting http://forums.pelicanparts.com/uploa...1354556102.jpg Cut and installed http://forums.pelicanparts.com/uploa...1354556142.jpg The next step was running an outlet hose from the T down through the plug above the windshield washer motor. http://forums.pelicanparts.com/uploa...1354556206.jpg The final step was running the car for about 15 minutes to ensure that the tank was being vented adequately. It was and the Rat ran like a champ with the new vent system:D. |
PS - don't use regular vinyl tubing for the emissions system; get vapor rated hose (looks like regular vinyl) |
sure - find a hose shop for the good stuff
I think I will use a coat hanger to estimate the wt. of the bows. How many are there on your car? I am just curious if the felt material used on the typ R saved any wt. ... |
| All times are GMT -8. The time now is 10:35 PM. |
