| French Import |
				First Engine Drop
			Must be the season as I see a few threads on engine drops this week. Anyway here are my questions: All instructions say to disconnect the fuel lines. I found and disconnected them from the fuel filter (no accumulator on my 86). What other fuel lines do I need to disconnect before the engine drop? Do I also need to disconnect hose #34?  Thank you Gerry for the picture.
				__________________ Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!  86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate Last edited by zippy_gg; 10-31-2012 at 01:47 PM.. | ||
|  10-31-2012, 01:41 PM |
| Registered |
			Do a partial engine drop and you'll see what needs to be disconnected.
				__________________ 1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera | ||
|  10-31-2012, 01:51 PM |
| French Import |
			Hmm... I expected more detailed from those with same model/year car. I will be doing this drop solo with a jack so I'll have to be careful about balancing the engine while slowly lowering it (instead of dropping  ).
				__________________ Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!  86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate | ||
|  10-31-2012, 03:29 PM |
| Registered |
			There are only 2 fuel hoses that need to be disconnected. The first is the high pressure supply line that exits the fuel filter and the second is the low pressure return line that hooks up at 11a. 34 does not need to be disconnected unless you are going to remove the MAF and intake elbow before engine drop.
				__________________ Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 10-31-2012 at 03:46 PM.. | ||
|  10-31-2012, 03:40 PM |
| Registered | Quote:
 If your motor's up in the air balanced on one jack and it gets wobbly, and you're by yourself, there's little to do but get out of the way... However you do it, go slow and keep an eye out for anything still connected or that got hung up as you separate the car and motor. Anything you missed or forgot to disconnect will be pretty obvious. Good luck!
				__________________ Audi 88 911 coupe felsengrünmetallic/graugrün 86 911 coupe silbermetallic/weinrot - gone but not forgotten 99 Boxster - gone but still in the family Last edited by audi; 10-31-2012 at 04:57 PM.. | ||
|  10-31-2012, 04:54 PM |
| Registered |
			zippy_gg, sjf911 is correct. There are only the 2 fuel lines to disconnect. The others you have marked can stay connected. Just go slow with the jack. Make a platform to give it more width if you can and it will stabilize things out.
				__________________ Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90) 08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK | ||
|  10-31-2012, 06:05 PM |
| Registered |
				Recent emgine drop........
			Four weeks ago, I dropped the engine of '87 Carrera to inspect the clutch disc and disconnected the following: Delivery fuel line Return line Brake booster vacuum hose Disconnected 3 electrical plugs left side of engine and 4 on top of the egine Ground wires left side 14-pin connector Ignition coil cable Hose behind air box 2 hoses from throttle body going to the right side of engine bay Square connector behind engine (center left) CV joint S-hose Oil line to aux. thermostat A/C transmission linkage (tunnel) clutch cable starter cable transmission ground strap accelerator linkage speedometer wire from sensor sway bar engine breather hoses disconnect batter cable And a few things that I forgot........ Tony Last edited by boyt911sc; 10-31-2012 at 06:08 PM.. | ||
|  10-31-2012, 06:06 PM |
| French Import |
			For clarity sake, the items in purple are the lines to be replaced once the engine is out of the car.  I borrowed a picture posted by Gerry to try and identify the fuel lines I need to disconnect for the drop. I tried disconnecting 11a but that little bugger is really tight...  Is the brake booster line represented in the diagram? I thought it was 34 but was corrected earlier.
|  10-31-2012, 06:51 PM |
| Member 911 Anonymous |
			Just at fuel filter ;-)  I'm in the valley allot. Pm me if you need a hand or moral support. Jim
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  10-31-2012, 06:55 PM |
| French Import | Quote:
|  10-31-2012, 07:53 PM |
| Registered |
			Draco has offered me suggestion in the past that have helped. Good to see you have him close by for support.
|  10-31-2012, 08:07 PM |
| French Import |
			Thanks to Jim (Draco) who came by this morning my engine is now on the floor.  After separating the tranny from the motor we checked the clutch and found it was worn down to the rivets on the flywheel side. Time for new Sachs parts!  The original Boge rear shocks were toast.  Next the banana arms come off for new polybronze bushings... Oh yeah... I am just Jim will post the mandatory "jack in the box" picture he took of me in the engine bay...
|  11-03-2012, 06:40 PM |
			Mais Bien Sur,
|  11-03-2012, 06:51 PM |
| Registered |
			Congrats zippy_gg, let us know when you get it back together.
|  11-03-2012, 07:09 PM |
| French Import |
			You bet Fbeatty! But it may take a while as I am replacing all suspensions and brake components, and some electrical work. I'll update this thread as I make progress.
|  11-03-2012, 07:16 PM |
| Registered |
			Cool, keep in touch. I have to get the bell housing on my transmission fixed so I am in the same boat. It is going to be a while
|  11-03-2012, 07:42 PM |
| No sleep 'til... BROOKLYN |
			Bien joué zippy Take care
				__________________ -Orlando- '89 3.2L G-50 '77 S w '79, 3.0L '90 T-3 Syncro 32C #16 | ||
|  11-04-2012, 02:17 AM |
| Registered |
			Looking great!  Keep us informed and lots of us pictures too
				__________________ 1987 911 Carrera | ||
|  11-04-2012, 03:52 PM |
| French Import |
			Removing the rear wheel bearings is a real joy... Driver side  Passenger side
|  11-04-2012, 07:47 PM |
| Registered |
			Subscribed!  Gilles, je vais te joindre bientot. Je suis dans le meme bateau! I'm planning my first engine drop sometime this winter, so please keep us posted Zippy! Alex
				__________________ Alex '80 911SC Targa '06 997 C4S Coupe - SOLD '07 997TT Coupe | ||
|  11-08-2012, 02:12 PM |
