Porsche Crest 911 won't roll
With car out of gear and em brake off wheels will not turn freely! I can be on a slight hill or want to push it and it will not roll any ideas!
Old 11-11-2012, 06:11 AM
Most likely emergency brake pads stuck on. Less likely car still in gear.
69 911 2.3Ez
85 928S
Old 11-11-2012, 06:18 AM
Danny_Ocean's Avatar
When you shift can you feel the "click" of the linkage engaging?
Old 11-11-2012, 06:20 AM
tharbert's Avatar
Welcome to Pelican, Runsurfer. You're going to have to provide A LOT more inforrmation here. You should start by what car you have. For instance, we don't know if it's a Passat or a 911. Year? Pictures would be nice.
What have you done to the car? Brake job recently? Has it been sitting for a long time? There are a number of reasons why any car resists rolling, brakes, bearings, alignment, tires...
And, I'll throw this out there as well. Become familiar with the search function on this site. You will find the answer to your question.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-11-2012, 06:25 AM
kodioneill's Avatar
Plugged flexible brake lines are always suspect.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-11-2012, 06:49 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Make sure it really is out of gear, when safe, try starting her, if she jolts, there you go. If not then it has to either stuck caliper/s or e-brake frozen.
Worse case CV joint failure/frozen, I doubt this, it should still move but you will hear clicks.
'85 Carrera Targa
PCA/POC
Old 11-11-2012, 07:27 AM
ivangene's Avatar
I would like more info
car year, and miles
last time driven - how many time / year driven
last brake service
last fluid flush
has it been jacked up and each wheel checked - if so do they ALL stick or just 1-2
calipers get sticky when in need of servicing
Ed M
86' Coupe
Old 11-11-2012, 08:27 AM
Senior Advisor
James Brown's Avatar
time to rebuild your calipers, do all 4, thank me later...
08 Cayenne Turbo
Old 11-11-2012, 10:34 AM
you have to put in in gear with the engine running for the car to go. Doy..
you should be able to tell if the e-brake is stuck by the loose leaver. and if it is you can spray some lube on the plungers on the backing plates and smack them with a hammer lightly. Thats usually where they stick
Old 11-11-2012, 02:43 PM
The original nylon pedal bushings are prone to sticking not allowing the pedal to return. The cure is the replacement brass bushings.
I had this problem once.
76-911s 80-911sc
Regards Lester
Old 11-11-2012, 03:38 PM
Rescuer of old cars
Arne2's Avatar
Could be the old "915 stuck in reverse" too. Way too many options here. Need more info.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 11-11-2012, 03:52 PM
