With car out of gear and em brake off wheels will not turn freely! I can be on a slight hill or want to push it and it will not roll any ideas!
Most likely emergency brake pads stuck on. Less likely car still in gear.
69 911 2.3Ez 85 928S |
When you shift can you feel the "click" of the linkage engaging?
Welcome to Pelican, Runsurfer. You're going to have to provide A LOT more inforrmation here. You should start by what car you have. For instance, we don't know if it's a Passat or a 911. Year? Pictures would be nice.
What have you done to the car? Brake job recently? Has it been sitting for a long time? There are a number of reasons why any car resists rolling, brakes, bearings, alignment, tires... And, I'll throw this out there as well. Become familiar with the search function on this site. You will find the answer to your question.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross Last edited by tharbert; 11-11-2012 at 07:31 AM.. Reason: sp |
Plugged flexible brake lines are always suspect.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Member 911 Anonymous
Make sure it really is out of gear, when safe, try starting her, if she jolts, there you go. If not then it has to either stuck caliper/s or e-brake frozen.
Worse case CV joint failure/frozen, I doubt this, it should still move but you will hear clicks.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I would like more info
car year, and miles last time driven - how many time / year driven last brake service last fluid flush has it been jacked up and each wheel checked - if so do they ALL stick or just 1-2 calipers get sticky when in need of servicing
Ed M 86' Coupe |
Senior Advisor
time to rebuild your calipers, do all 4, thank me later...
08 Cayenne Turbo |
you have to put in in gear with the engine running for the car to go. Doy..
you should be able to tell if the e-brake is stuck by the loose leaver. and if it is you can spray some lube on the plungers on the backing plates and smack them with a hammer lightly. Thats usually where they stick
82 SC , 72 914 Last edited by porsche930dude; 11-11-2012 at 03:46 PM.. |
The original nylon pedal bushings are prone to sticking not allowing the pedal to return. The cure is the replacement brass bushings.
I had this problem once.
76-911s 80-911sc Regards Lester |
Rescuer of old cars
Could be the old "915 stuck in reverse" too. Way too many options here. Need more info.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
