Best A/C on a 911?
Chris '75 911s Targa |
Banned
Not in North Texasssss - that system is completely ineffective from April well into November (unless you enjoy being scallded by the sun and cooked by the heat and humidity while going from point A-to-B, buttofcourse )!
![]() Last edited by Ronnie's.930; 03-31-2015 at 01:50 PM.. |
I'm in Central Florida, I know all about the heat and humidity! It's just the Targa is such a superior design compared to the coupe, I don't need no stinking A/C.
Fleabit peanut monkey
I am afraid Ronnie is correct.
Texas heat is genuine. Florida heat is simply fashion. Something spoken of rather than truly endured. Agree. I am actually interested in the tech aspect. I hope this AC thug is on to something. ![]()
1981 911SC Targa |
Banned
Chain fence eating turbo
And North Tejas doesn't have $&!7 on South Tejas heat!! |
North Tejas heat is more realer. Way to many therms, just less wetter.
1981 911SC Targa |
Dunno Bob, it's gets more hotterer since the humideee is worserer :/
Banned
^^^ I'll telt youse twoes one place in Norf Texazz it's most definitely NOT hot . . . insides my meat wagon (in more ways than one) of a almighty, 911 Turbo (a Coupe, BUTTofcourse)!!!
OMFG
These dudes wrote a song about you, Dousche-a-tonious.................... Made loud to play loud.
1981 911SC Targa |
Banned
Little know fact - Bob wrote the following song while struggling with his troubling desire for Targa ownership! |
If the pain goes on, I'm not gonna make it.
1981 911SC Targa |
Banned
^^^ Bob, I think you should do an audio recording of that lyric in your best Cory Taylor voice and post it here - dooooo ittttt, nooooowwwwww, bro!!!
1981 911SC Targa |
Banned
![]() Quote:
“Hi Reid, It looks like you have two 10 foot hoses in a temporary hookup to reverse the condenser order. Were yo able to route those hoses, and have the function you were looking for? Thanks, Dave __________________ Dave McKenzie 1984 Carrera 3.2“ Absolutely! IT WORKED BETTER THAN I COULD EVER HAVE IMAGINED ! Buy some temporary cheap hose, hose clamps, and fittings to fit your condenser etc connections This will cost you maybe $50-$100 Simply Disconnect your hoses leaving them in place Connect the new temporary hose, reversing the gas flow from stock/OEM mentality and you will prove this works FOR YOURSELF Don’t let the repair/aftermarket shops take this information from my discovery apply it and hide it from you and other DIY’ers and use it to make money from you after they see this information ! TRY IT YOU WILL LIKE IT !!! Last edited by KelogGes; 04-01-2015 at 06:56 AM.. |
Instead of using the term, "reverse flow", I suggest substituting terms such as regurgitate, recycle, back flush and other non-descriptive terms for this potentially viable strategy. I think you'll get less push-back from the tech crowd.
Sherwood |
Reroute is the best term IMO
KeloGes;
![]() Just to be clear... I believe that no one, myself especially, has any question as to whether or not your high pressure side flow re-arrangement will work. The question I have, based on the airflow measurements and physical size of the front and rear condensers that I published, just what was the overall improvements in A/C performance? I note that the front condenser you seemed to use is not factory and therefore may be more efficient, thereby biasing the system in favor of your statement. On the other hand I suspect the fan you used to cool the front condenser was less capable than the factory blower so maybe that is a "push" overall. You seem to be a champion of tightly sealing the engine lid against bypass cooling airflow. How did you accomplish that while using those external hoses? Also not sure what you think is accomplished information wise, publishing the guage readings. Can you explain? Finally. Do you have any evidence whatsoever that would indicate to readers of this thread that there was actually an improvement in A/C performance gained by re-routing vs not? Before and after data using the none standard front condenser/fan arrangement in both cases? Say comparative rate at which each configuration pulled the cabin down from ambient to a specific temperature level..? ![]() |
KeloGes;
Did you at all consider that with the high side pressures/temperature indicated by the guages that extra cooling via 20 feet of hose might have bias your "test" quite substantially? |
Thread Tools | |
Rate This Thread | |
