Banned
Good luck with that Scott
Thanks Al and great work so far. I spoke to him a couple days ago. He is only interested in the intake parts and, right now, I am trying to sell the whole package (DME, harness and intake parts) right now..
Thanks, Scott Quote:
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
Dean
Dean |
Racer
Yes, the rear chassis crossmember was removed. We can get away with that because of the cage and the fact the engine crossmember is quite stiff when bolted on place. Some people use additional bracing but we have no indication that this is necessary. It sure makes engine removal easier especially if I want to keep the transaxle in place. The engine is a stout 3.6L it makes 369 RWHP and and 290 ft-lbs RWTQ. The architect is William Knight and it was built by Mat Lowrance.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Dean |
Rasant induction/wiring/ignition. Very hot 2.8L build. Motec M130. We have had to refactor some of the harness to suit our needs, hence the stripped down loom you see...
Here is my new setup running quite well, still needs some tuning plus a valve adjustment and oil change. Hope to pick it up this weekend.
New-ish 911SC Targa Owner
I'm looking at the RHD setup to replace my triumphs but i just don't care for the look. Much rather a cast throttle body than a machined.
however, i do like the RHD pricing!
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Racer
Reno Rennsport sells them. Awesome ITBs.....
JSR Elliptical Roller Barrels
Not bad for a 2.7L street engine
Full Send Society
@Nux, you pulled 271HP out of a street 2.7?
Tell me how! That's damn impressive!
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html Last edited by Showdown; 04-06-2021 at 10:33 AM.. |
Nice numbers. A street 2.7 that revs to 7250+ RPM, hmmmm?
Not to shabby eh? The build: Stock (blueprinted) 2.7 short block. 10.5CR, twin plugged and lightly ported heads. Megasquirt ECU driving coil on plug CatCams camshafts JSR small bore ITBs, Bosch Injectors Original headers M&K muffler 271HP with completely flat and smooth 279nm of torque |
Administrator
Found this beautiful image posted by one of our community members on 986 Forum.
Yes it revs All the way. No problem for a.2.7
Check out out here: https://www.instagram.com/p/CGfy_Afl9CU/?igshid=tr8fa64n8wg7 https://www.instagram.com/p/CGfVwhWl-6o/?igshid=nbsdxhhitnwo |
Full Send Society
Damn, if I had what, ~10k lying around I'd be all over that. 271HP in a narrow G weighing what 2300lbs (my 77 is down to about 2250LBS)... Lord that must be fun to drive. Nice work for sure! And those videos:
![]() Quote:
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Which component in your build list do you think is the biggest individual contributor to your the numbers below?
My build will have the following: 3.2 factory euro rebuilt from crank, heads fly cut factory cams (wanted to go webcam 20/21 at rebuild but couldn't) MSD streefire, keeping dizzy XF-RHD 42-45mm throttle bodies w/ direct to head adaptors injectors (30lb/hr) SSIs (like the early torque the "just right tubes" introduce, many opinions on this) Dansk 2 in 1 out (I have a targa with the top off most of the time) Also, is the dyno known to be gracious (some are quite a bit)? Quote:
The JSRs contribute quite a bit though. We had another 3.0L twin plugged on the dyno that day, and it whent from 243hp using Triumph ITBs to 265hp using JSR ITBs. Nothing else was changed. Also, we had a 3rd car on the dyno - a stock 3L with good exhaust, and Triumph ITBs making 215hp which was a little dissapointing imo. So the dyno is not very gracious. Last edited by Nux; 04-07-2021 at 04:31 AM.. |
Sounds good and thanks for the info. Al's kit has shown very nice dyno numbers on a 3.2 setup similar to mine along with a somewhat gracious dyno.
I cannot wait to drive my new setup. Would you consider the CatCams similar to a webcam 20/21 or 964 cam? Quote:
O.K. ... So after some 19 pages of Gold Card vibrato stories and selfies, just what kinda highway steady ankle throttle mpg's is everyone realistically now getting with 6 throttle bodies instead of having just one ? ... yeah it matters.
antares fatnwide - uncle dave 79 steel wide body Targa / euro 915 oil cooled LSD / SSI's / RUF 8 & 10's / Monty M22 / Alum flywheel plus lots of other silly little mods n upgrades |
