a/c question
Hello. i have a question. on my 79 SC my a/c has a leak between the clutch and compressor. has any one ever had this problem. if so any advice is greatly appreciated thank you very much.
sylvester |
Hi Sylvester,
That is a compressor shaft seal leak. It is the main external compressor leak problem. It is common depending on age and condition. The compressor can be rebuilt or depending on its other problems it can be replaced with a new or rebuilt or updated compressor. Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Ok... thank you for the reply.
sylvester |
Is the compressor a stock York or an aftermarket?
Kuehl 1987 911 cab, modified https://griffiths.com/ |
I had this very same problem. I tried to replace the nose seal but compressor was shot. I bought a rebuilt unit on Ebay and it works fine. Cost was about $200.
Hello.. yes it's a stock York compressor.. I'm going to open it up check it out and report back in a few days thank you.
sylvester |
Take the compressor apart to take a look see. Unless you are a super meticulous careful rebuild guru, you likely will just waste your time buying a seal kit. It is a real challenge to rebuild one and usually they have enough wear the entire compressor is junk anyway. They are not cheap, but not too crazy expensive.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Ok.. I might buy a new compressor no big deal.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Ac pump
http://www.discountacparts.com/Porsche-911-AC_Kit-60~84594_RN.html
^^^^^ I bought a new pump from these folks. I think they are in San Diego. Great service. Nostalgic AC - Binary Switch w/ R-134a Discharge Port 3/16" Port - AC Pressure Switch - Oil, System Flush & Switches ^^^^^ Also bought switch. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
86 911 tanga thank you sir.
Thread Tools | |
Rate This Thread | |
