Writer/Teacher
changing front rotors
When you change the front rotors, do you need to replace/remove the wheel bearing seal, or is it as easy as the Haynes manual makes it seem:
remove brake pads remove caliper undo dust cap undo lug nut pull off rotor ???
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
You can do it on the car if you are a bit lucky....
The rotor is bolted on the hub - IF you can undo the bolts with the hub on the car - go for it. Otherwise, you will have to remove the grease cap, loosen and remove the hub nut and remove the hub\rotor and then remove the rotor from the hub. If you remove the hub, IMO you should at least replace the seal and repack the bearings with fresh grease. When replacing the hub nut - it is tight enough when you can just move the washer behind it. Tighten the allen bolt to 11ftlbs. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
the bolts that connect the rotor in the hub can be a pain to get at from where they are...... otherwise it is as simple as the haynes manual explains...
You are better of pulling it the hub completely out and doing it like AF explains.... Its a good idea to (replace the bearings if needed) and use a new seal.... The rears on the other hand can be done with your eyes closed..
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
I would suggest pulling the pads and calipers off first. Use some wire to hang them from the strut so you don't bent the brake tubing.
I've not had problems getting the rotors off of the front hubs with then still on the car. Still this is a good time to inspect and repack the front bearings if you haven't done it recently.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Writer/Teacher
thanks for the info. i will attempt to do this without removing the hubs, if at all possible
also, can anyone tell me the size of the allen socket that i will need to use... just to make sure I can aquire it from a friend if i don't have it here
Think it is 6MM
AFJuvat
It is 6
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
Also make sure the outer bearing doesnt fall on a dirty surface when u take off the hub ..if u have to.
Writer/Teacher
thanks guys... i will be doing this on thursday, so i will post pics of the finished product
